07-26-2013, 09:03 PM | #1 |
COTW 12/3/12
Drives: 2012 Ashen Gray ZL1 Join Date: Aug 2011
Service Suspension after installing lowering springs
I installed Pedders lowering springs today and everything went pretty well. Except now when I start the car, the "service suspension" comes up on the DIC. Once I clear it, it stays off and the cars handles and drives like it did before the install. Has anyone experienced this before? I sent JusticePete a PM asking but thought I would see if this happened to anyone else. All plugs were put back exactly as they were removed and I do not get any warning lights on the dash except at startup. All suspensions modes also work normally. The light only comes on at startup and is easily cleared. Nothing else seems out of the ordinary except the initial message.
I did not unplug the battery during install. Could this be the problem? Any thoughts or suggestions? I'm stumped. Sent from my iPhone using Tapatalk 2 |
07-26-2013, 09:07 PM | #2 |
Drives: 69 Chevelle SS396 2013 ZL1 Join Date: Mar 2010
Just for the sake of conversation because I have not done this and JusticePete will look after you.
But did you install shorter pushrods for the suspension sensors?
07-26-2013, 09:14 PM | #3 |
Drives: Camaro's, always have, always will. Join Date: Oct 2010
...don't sweat it, wait for the response. You are in good hands....
07-26-2013, 09:28 PM | #4 | |
COTW 12/3/12
I am sure Pete will get back to me as soon as he is able. Until then, I'll just press clear! Sent from my iPhone using Tapatalk 2 |
07-26-2013, 10:11 PM | #5 |
Drives: 2013 ZL1 Vert Auto IOM Join Date: May 2012
I would try disconnecting the battery for 30~ minutes and then reconnect and see if the message returns
07-27-2013, 12:00 AM | #6 | |
COTW 12/3/12
07-27-2013, 03:32 AM | #7 |
Drives: 2013 Camaro ZL1 Join Date: Dec 2012
Are the connections tight on the rear shocks? I know on my car the connector after being modified to fit onto the new spring was loose that caused the light.
07-27-2013, 09:08 AM | #8 | |
COTW 12/3/12
07-27-2013, 12:13 PM | #9 |
Drives: 2013 ZL1 Join Date: Dec 2011
Looking to install the same coils in my car...I think I'll wait to see what you find out first
Hopefully it's something simple...good luck figuring it out! |
07-27-2013, 04:54 PM | #10 |
Camaro Addict
Drives: too many Join Date: Sep 2009
i installed the BMR split drop on my car with no lights afterwards. rear connectors were a pain in the butt. did you repin them correctly? so they are not reversed?
1990 IROC-Z Vert LS
1996 SS Vert LT4 1992 Z28 Z03 T5 1992 Z28 Z03 L98 2018 Sierra Denali 6.2 1997 Z28 Z4C 1995 Z28 |
07-28-2013, 03:10 AM | #11 |
Can't stop ***ifying
I forgot to reattach one of the rear suspension sensor links. I had the same message. I just attached it started and drove car, all is well since
07-28-2013, 08:52 PM | #12 |
COTW 12/3/12
So I checked the plugs and they were all fine so I am guessing it's a pin issue. Tried to pull codes off the OBD II with a reader and the car came back clean- no codes at all. I'm thinking something is just a little bit loose because the suspension works fine and it's not throwing codes. It's not going to get fixed before the fest, but oh well.
07-28-2013, 09:01 PM | #13 |
Camaro Addict
when I did mine, I couldn't remember which wire went to what side of the plug. I guess I got it right, or maybe it doesn't matter, im not sure.
if the fest ever comes back to Georgia i'll be there. Cant make the haul around the country these days. Have fun there!!
1990 IROC-Z Vert LS
08-11-2013, 09:53 PM | #14 |
Deke...ever figure out the problem?
