07-09-2009, 01:19 PM | #1 |
I can't tpye!
After Market Mass Airflow Sensors.....true or BS
Saw this over on ebay:
"Product Code:JET-69143 Manufacturer:JET Performance These mass airflow sensors flow 41 percent more airflow then stock. The Powr-Flo sensors are designed to improve horsepower and increase gas mileage. They are compatible with factory electronics and stock vehicles, as well as modified vehicles including, but not limited to: Performance tuning (chips, modules, etc.), exhaust modifications (cat-back, headers, etc.), cold air intakes, and ignition systems." Seems a little to good to be true and haven't seen anyone discussing them. fact or crap? |
07-09-2009, 01:23 PM | #2 |
Drives: 2SS w/ ZZ427 Package!! Join Date: Oct 2008
I would recommend using the factory sensor and just tuning your car.
In my opinion these can be a waste of money. |
07-09-2009, 01:24 PM | #3 |
I can't tpye!
No plans to get one, jsut curious.
07-09-2009, 01:24 PM | #4 |
Booooosted.
Well, I may be having a problem in this area.
07-09-2009, 01:30 PM | #5 |
Okie doke
Typically your MAF can support up to a certain HP limit. I would say unless you are making GOBS of HP, your fine with the stock MAF and tuning ...
Crowley
07-09-2009, 02:55 PM | #6 |
Petro-sexual
I think a lot of these MAFs would also trick the computer into thinking it should add more timing and not always accruately represent true operating conditions. I'm with about everyone else - stay with the OEM one and tune unless you're making huge power and the OEM MAF is a restriction.
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
07-09-2009, 03:18 PM | #7 |
Drives: 2016 Corvette Z06 Blade Silver Join Date: Jun 2009
Back in the day these were useful for the 5.0 Mustang guys. The MAF on those cars was restrictive and to make big power you needed a larger one. Also they allowed a way to "trick" a stock tuned system to accept larger fuel injectors. Mind you this was before retuning the computer was common. On my 94 GT I picked up over 60HP on a Pro-M 77 MAF with a heavy modded 5.0 with a Vortech S/C.
On these cars it looks like a non-issue to date. <edit><--- AKA NOT NEEDED </edit>
2016 2LZ Z06 Blade Silver
2013 ZL1 BLACK on BLACK <SOLD> Roto-Fab CAI 2010 2SS/RS BLACK on BLACK <SOLD> 3" MBRP 304 Stainless Exhaust Roto-Fab CAI Last edited by BlackinBlack; 07-09-2009 at 03:30 PM. |
07-09-2009, 03:21 PM | #8 |
Petro-sexual
Yup. I think, more recently, they tell the PCM it is actually cooler outside so it will add timing to make more power. Personally, I don't like the sensors to lie to the PCM, so I'd rather consider tuning for an optimal AF ratio than this. However, if it's a restriction, that's a different story, IMVHO.
07-09-2009, 03:22 PM | #9 |
formerly "wh0rsep0wer"
Drives: 2016 1SS Summit White Join Date: Oct 2008
Everyone I've heard about that changed their MAF on the LS1 (on the LS1Tech Forums) had nothing but serious problems afterwards until the stock MAF was put back in. Juss sayin'.
2010 1SS/RS - CGM/Gray Interior - M6 (SOLD) Kooks 1 7/8" headers, Solo Mach-X, Vararam.
2012 2LS - Black A6 (SOLD) 2016 1SS Summit White A8 |
07-09-2009, 06:20 PM | #10 |
Drives: 05 CTS-V, 2010 CGM SS/RS Join Date: Jun 2009
From a tuners standpoint, I have to say that aftermarket MAF's are a complete waste of your money. I've seen the calibrations in them vary widely and the stock MAF sensor will flow plenty of air and there is no need for a larger one.
Similar Threads | ||||
Why I don't think the interior has mass market appeal | Eich | Cosmetics and Lighting Modification Discussions | 53 | 10-23-2008 11:59 PM |
Camaro ranks 8th in all time sales for GM | Bart | 5th Gen Camaro SS LS LT General Discussions | 16 | 09-16-2008 07:23 AM |
GM bankruptcy! | SSMUFF | General Automotive + Other Cars Discussion | 101 | 07-08-2008 11:44 PM |
