09-23-2015, 04:32 PM | #1 |
Drives: 2013 Camaro SS 1LE Join Date: Oct 2014
Radiator swap question
I'm changing my radiator in my 2013 to the 2010 rad so I can use the Vararam that I have. Problem I'm at is the fan shroud is different. Can I just order up the fan from 2010 ? Or is the plug different? If they are the same plug it will work. Thanks
09-23-2015, 06:19 PM | #2 |
Drives: cars Join Date: May 2011
Even if it's different it's a simple splice with a bit of solder and heat shrink to get it working.
