08-26-2016, 12:20 PM | #1 |
Drives: 2013 Camaro SS 1LE Join Date: Oct 2014
ls3 crank pulley
does anyone make a ls3 overdrive crank pulley?
08-26-2016, 12:25 PM | #2 |
Too much is never enough!
SLP, ATI, and innovators west all do.
https://www.google.com/#tbm=shop&q=l...nk+pulley+site Here are some from google. Sent from my iPhone using Tapatalk
Build thread http://www.camaro5.com/forums/showth...55#post8107855 Last edited by 1KillerSS; 08-26-2016 at 10:07 PM. Reason: Added web link for parts |
08-26-2016, 10:07 PM | #3 |
Updated my posting so you could see the available parts from a google search.
