09-13-2016, 06:58 AM | #1 |
Drives: 2013 Camaro SS 1LE Join Date: Oct 2014
Meth injection with LSA supercharger
Im thinking about adding meth to my lsa conversion. im seeing 12psi with my 2.5 pulley @14* timing and thankfully no knock on 93 octane yet. but i would like the added octane/safety from using meth. ive done some searching around the web and it seems that spraying pre blower will ruin the rotors. or so they say. but i never found any actual evidence of this happening. so for you guys spraying pre blower, how long have you done it this way? any damage to blower?
also i tried to find setups after blower but couldnt find anything. does someone make the spacer for the lid that i can use to spray meth? |
09-13-2016, 07:24 AM | #2 |
Drives: 2013 ZL1 Join Date: Jan 2015
While methonal is corrosive it should not be sitting on your rotors. Inject it at the elbow pre throttle body like has been done for years.
2013 A6 ZL1
09-15-2016, 08:10 AM | #3 |
Drives: 2011 Camaro SS2RS, 1970 Camaro SS Join Date: Aug 2015
Let me know what you decide. I'm at the exact same spot as you. Meth is the next step for me as well
Sent from my SM-G935R4 using Tapatalk |
10-06-2016, 10:01 AM | #4 |
got this setup done,ill try to post pics later. it was a DIY setup from another post on this board. but i ended up changing out the nozzle to snow 625ml instead of the mc master carr. didnt like mist size. boost went from 12 to 13psi. i pulled 4% fuel and still a little rich. at 16* timing. dont think i want to go any further on it. its plenty on the street. mix is 50/50.
