01-06-2016, 07:40 PM | #1 |
Drives: 2010 2ss RS. White (RIP) 2012 LS3 Join Date: Sep 2011
1le shocks on 2010 ss?
Will they work? Both front and rear on a 2010 ss. I have 1 inch lowering Springs I'll be putting on in the spring and figured if it's all apart..... Why not. I hear mention of different rear mounts? But anything else? Or will they just not work since the 2010 is fe3?
01-06-2016, 08:02 PM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
The 1LE rear shocks have a different mount and the are suppose to be a lot better than the SS shocks they are a single stage vs the SS are multi stage or vice versa. They are stiffer than than the SS so it might be a harsher ride along with lowering springs. Justice Pete can outfit your 1LE struts and shocks with Z/28 springs that also lower your ride.
Rear mounts are about 80 bucks each I'm going to start scouring all the GM website to find the best price on a set of mounts myself... My understanding is you won't be sorry you installed them!!! |
01-06-2016, 08:11 PM | #3 |
I already have the springs. I'm just trying to figure it what else is needed or if it's even possible to just slap some 1le shocks on the car with new Springs. And I can handle the ride. If I wanted it to ride like a Cadillac, I would have gotten, well, a Cadillac. So day for instance I have my Springs and the 1le shocks. What else is needed to install these on a 2010 ss?
01-06-2016, 08:54 PM | #4 |
Just the upper rear mounts...
01-08-2016, 07:47 AM | #5 |
Drives: 2011 Camaro SS/ 2016 Camaro SS Join Date: Jun 2009
The 1LE damper package is an excellent upgrade. You need the front struts, rear damper and rear upper mounts; that is it. Please feel free to call, email or PM us anytime with questions.
Kind regards, Jordan Priestley 888.308.6007 |
01-08-2016, 09:23 AM | #6 |
hates winter
Drives: Black 2010 2SS/RS LS3 Join Date: Nov 2009
Matt,
How bad are the roads in your area of NJ? I would have already made this upgrade with my Hotchkis lowering springs if I wasn't so concerned about the suspension slamming on uneven/patched roads. Right now with the lowering springs (and 77k on the original shocks) it is pretty firm. Do you track your car? Jordan, What is the benefit in going with the 1LE dampers on a road car? Sean
Traded car Aug 2019.
2010 2SS/RS LS3 built October 30, 2009; 416ci/6.8L forged LS3 with 495 RWHP@6k/470 TQ@4.4k; Lunati 235/243 .626"/.634" 114LSA +3; Monster LT-1S twin disc, SLP retro badges, MGW shifter/knob, Hotchkis TVS Stage 1, Pedders Street Z bushings, 3.91 Gear swap, red calipers, Z28 CAI, ZL1 side skirts/rock guards, Kooks 1 7/8" headers, SLP front splitter. |
01-08-2016, 12:33 PM | #7 |
Drives: 2010 2SS/RS Join Date: Jul 2014
What is different as far as the upper rear mount for the 1LE?
Current car
2011 Backdraft RT3 427 stroker (DART block/ forged internals/ AFR 205 Aluminum heads/ Quickfuel 750) 600hp/590ftlbs, wilwood brakes, custom JRI double adjustable shocks. Weighs in at 2300 lbs.... Use to have 2010 Camaro SS - ECS SC 1500, Kooks LTH + HFC, Corsa, CTS-V brakes, Detroit Speed Coilovers, BMR sways (FE4 conversion), DSE endlinks, BMR toe rods and trailing arms, Forgestar F14's |
01-09-2016, 08:21 AM | #8 | |
It has a stiffer upper bushing which means there is less deflection before the shock is able to dampen. The soft bushing will move before the shock is able to do it's job where the stiffer bushing has less movement and the shock starts working earlier. Kind regards, Jordan Priestley 888.308.6007 |
01-09-2016, 10:00 AM | #9 |
Drives: 2010 camaro ss Join Date: Jun 2010
I have the 1le shocks on my 2010 and I don't recall using anything else to install them
01-09-2016, 02:40 PM | #10 |
But isn't the bushing part of the shock not the mount???
01-09-2016, 04:36 PM | #11 |
Drives: cars Join Date: May 2011
No its in the shock mount.
They're not needed to use or install the 1LE shocks, there's very little difference between the 2. |
01-09-2016, 06:04 PM | #12 |
Drives: 2010 2ss red LS3 Join Date: Aug 2011
While you are at it, update the rear lower control arms and sway bar. $0.02
Pedders Pace Car Kit with ZL1 sway bar conversion & camber bolt kit.Lowered 1.5". 1LE tires & wheels. CAI air intake. Anvil CF rear spoiler.MGW shifter. 1 7/8" Kooks LT headers & HF cats.V-Max ported TB. Tuned.
01-09-2016, 06:52 PM | #13 | |
Banned
Drives: 2011 Boxster Spyder (best car ever) Join Date: Aug 2014
01-09-2016, 07:07 PM | #14 | |
'It's an experiment'
Waiting on CF solid driveshaft... -Don
747 RWHP 794 RWTQ
