JUICEDMOTORSPORTS
Old 07-30-2010, 10:57 PM   #1
Fogey
Fogey's Avatar
Drives: 2011 2SS/RS A6, IOM
Truly ignorant question, but I'm old
Getting a 2011 RS/2SS in about 3 weeks. Is there a way to play my iPhone 4 IPOD thru the Camaro sound systems?
Fogey is offline   Reply With Quote
Old 07-30-2010, 11:06 PM   #2
Kycamaross
RED JEWEL inthe BLUEGRASS
Kycamaross's Avatar
Drives: 2010 RJT 2SS/RS, 01 S-10 Xtreme
If you got the 2SS, then I believe it should work through your USB port in the Center console. You just need to get the correct cables.
Kycamaross is offline   Reply With Quote
Old 07-30-2010, 11:12 PM   #3
Eric's Blue
Eric's Blue's Avatar
Drives: Cybergray 1SS
My IPOD works fine it... But I have an older model Iphone that registers as not compatable. You might go to your dealer plug one into his.
"Thou shalt not covet thy neighbor's SS"
Eric's Blue is offline   Reply With Quote
Old 07-30-2010, 11:14 PM   #4
smaegley
smaegley's Avatar
Drives: 2010 Camaro 2SS/RS LS3 IBM
Try a search of http://www.camaro5.com/forums/forumdisplay.php?f=29. But yes, it works fine. You want to make sure you connect the GMusicConnect bluetooth to play music and connect the General Motors Bluetooth for the phone. Or you can use the USB to connect the cable to the dock port. I use Bluetooth because I hate the iPod interface on the stereo.
smaegley is offline   Reply With Quote
Old 07-31-2010, 12:24 AM   #5
Pumpkin1LT
Pumpkin1LT's Avatar
I have a 1LT and a cable.. Works just fine.
A happy wife is one in the garage getting dirty under her 2010 Camaro!
Pumpkin1LT is offline   Reply With Quote
Old 07-31-2010, 05:07 AM   #6
Brownhornitt
Brownhornitt's Avatar
Drives: 2006 White Corvette Convertible
Yep. And as pointed out, there are three ways to do it. With the 2SS, you will have your choice between aux in, USB, and bluetooth.
The Corvette is an animal.
Brownhornitt is offline   Reply With Quote
Old 07-31-2010, 06:49 AM   #7
RipperFox
Grrr!!!
RipperFox's Avatar
Drives: BLK/IOM '11 2SS/RS
+1. Yup works
Rules for ordering a car.
1. Dealers are liars
2. Buy off the lot
3. See rule #1
RipperFox is offline   Reply With Quote
Old 07-31-2010, 06:58 AM   #8
trm0002
VIN #2G1FT1EW6A9100074
trm0002's Avatar
Drives: 2010 CAMARO 2SS/RS RJT VIN 00074
Send a message via AIM to trm0002
iPhone4 software (even on the 3GS model) is incompatible with the bluetooth. You will have to plug into the USB port until a software update fixes it.
To answer your original question, your iPhone4 will work just fine through the USB port as an iPod.
The "correct" cord is the standard USB cord you use to connect your iPhone to a computer. Nothing special.
trm0002 is offline   Reply With Quote
Old 07-31-2010, 09:21 AM   #9
mhood
Orange Camaros Rule!
mhood's Avatar
Drives: 2010 1SS LS3 RS IOM
Aux in works gr8 with my iPod. If your iPhone has a typical 3.5MM headphone jack, then it should work fine via Aux in.
mhood is offline   Reply With Quote
Old 07-31-2010, 09:55 AM   #10
Captain Awesome
That's odd. It works great with my Droid.
Captain Awesome is offline   Reply With Quote
Old 07-31-2010, 10:35 AM   #11
trm0002
trm0002's Avatar
It worked great before the 4. update...
Old 07-31-2010, 11:07 AM   #12
yzfmik
yzfmik's Avatar
Drives: '10 Summit White 2LT M6
My iPhone 4 works via Bluetooth for listening to the iPod or streaming music from the internet. Never had a problem since release day (for the iPhone 4).
'10 Summit White 2LT M6, 5% Tint
yzfmik is offline   Reply With Quote
Old 07-31-2010, 11:08 AM   #13
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
works fine with my iphone 3g so I think you should be fine.
however, sometimes it says "Data could not be supported"... just take the cord out of the iphone and plug it back in and works again.
also, sometimes when I go to playlists it gives me names of songs instead of playlists just press back on the car controls and click playlist again and it should read perfectly.
so there are some imperfections yes, but it's not that bad
Old 07-31-2010, 11:11 AM   #14
ihaveacamaro
I like teeth.
Drives: #198
true but I've compared how the usb plug sounds vs the auxiliary and using the usb makes a HUGE difference to sound quality.
Since the OP will get a usb port in his car, I suggest the OP use that
Question about tire sizes Jram1588 Wheels and Tires Talk Sponsored by The Tire Rack 9 07-17-2010 07:27 AM
Ignorant Tech Question Fogey Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 12 07-06-2010 03:55 AM
Custom wheel offset question ... Bowtie Junkman Wheels and Tires Talk Sponsored by The Tire Rack 4 04-23-2010 05:16 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 06:53 AM
Question re: c.i. displacement and hp Arli 5th Gen Camaro SS LS LT General Discussions 6 03-24-2009 01:20 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
