09-12-2014, 08:49 AM | #1 |
Drives: 2011 Camaro 2SS RS SIM Join Date: Aug 2014
Halo color change kit
Hey guys im looking to buy a halo color changing kit, I have a camaro ss2 2011 which kit would be the easiest to install and the best kit to buy?
Thanks. |
09-12-2014, 01:58 PM | #2 |
Bump!
09-12-2014, 02:40 PM | #3 | |
Buckeye
Drives: 2013 2SS RS 1LE Join Date: Apr 2012
http://nightowlleds.com/ It took me about 5 hours to do the install as both head lights have to come out and the LED inside the headlight must be changed. The install is not difficult, but it will take some time.
09-12-2014, 03:30 PM | #4 |
Mid-Florida Camaro Club
I got the one from Gen5dyi
http://www.gen5diy.com/Lighting/rgb-...lo-upgrade-kit Installing the kit is the same on both, it all depends on the additional upgrades you might add later on what you buy. |
09-12-2014, 04:00 PM | #5 |
Drives: Red V8 Join Date: Jul 2014
you can also try this search link, it has a lot of option for Halo lights on the 5th gen
http://www.rickscamaros.com/catalogs...t/?q=Halo+2010 |
09-12-2014, 08:51 PM | #6 |
Hmm i will be looking into those links see which ones i like more
09-12-2014, 09:55 PM | #7 |
Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi Join Date: Apr 2009
You need RS for the standard NightOwlLEDs halo kit. If you have that, I'm a strong +1!
09-13-2014, 08:49 AM | #8 |
Doc
JDP Motorsports halo kit
Sent from BLACKOUT using Tapatalk
1100-7/20/2009 * 6000-2/4/10 Proud Owner of Autographed Litho # 1282010 Camaro 2 SS/RS - BLACKOUT & 2017 Camaro 2 SS - 50th Anniversary #894 WWW. NY5THGEN.COM
09-13-2014, 08:52 AM | #9 | |
#TeamBeckyD
Drives: 2017 HBM 2SS Convertible A8 Join Date: Aug 2008
#TeamBeckyD
**FIFTY HBM 2SS VERT** |
09-13-2014, 09:44 AM | #10 |
I do agree totally on the Night Owl kit but for now I am on a budget so will stick to the $60 Wi-Fi system until I save up for the Night Owl module.
09-13-2014, 10:11 AM | #11 |
Drives: 2011 Camaro 2SS/RS M6 - "Mabel" Join Date: Dec 2013
i too have a 2011 SS and would like information on color changing.. Now is it true that you can just change the led in the RS lights without changing the entire halo out? And if so wouldnt a multiple color choice LED work for this such as night owl system?
09-13-2014, 10:29 AM | #12 |
Todd
do you need to take apart the headlight for gen5diy halo color changer?
09-13-2014, 11:11 AM | #13 | |
#TeamBeckyD
In all if you have no experience it should take approx. 5 hours with experience 2-2.5 hours. As I mentioned before the longest part is removing everything to get the headlights out.
#TeamBeckyD
09-13-2014, 01:16 PM | #14 |
Drives: 2011 2LT RS IOM Convertible Join Date: Dec 2010
I did the Gen5diy kit and technically no you can remove the LED without taking the headlight apart. My friend did it that way. After 3 hours of trying to remove the 4 screws that hold in the LED I gave up and baked them. It was much easier that way. I looked at the Night Owl kit but at almost triple the price of the Gen5 kit I decided the cost was too high for my budget. I am very happy with the kit I have it looks and works great.
