Old 12-22-2018, 11:07 PM   #1
Artt
Drives: Red 2010 SS
Color code placement for upstream O2 sensor connector
Hey guys i need some help here, i bought a 2010 camaro from a kid who was bracket racing it at our local track in Springfield Misouri. Brought it home and found a bunch of issues. Got most worked out but when i drove 500 miles round trip to KC for a dyno tune I found out my 2 front/ upstream O2 sensors didnt work. Got hom and found out they were not on the car. Somone cut off the pigtails/connectors from the harness and was running the rears only. The car has 1 7/8 headers, cam, cold air and all the supporting mods......supposedly. Big question is does any one have the color code pin placement for the pig tails. I found the 4 wires for each side taped off but dont know the pin placement for the new pigtails........any help would be appreciated.
Artt is offline   Reply With Quote
Old 12-23-2018, 12:43 AM   #2
Codiath
brakes for squirrels
Codiath's Avatar
Drives: 2012 45th Anniversary 2SS
hope this helps
Name:  o2 sensor.jpg
Blue wire to pin-B
White wire to pin-A
Black wires to pins-D,E
Codiath is offline   Reply With Quote
Old 12-23-2018, 01:27 AM   #3
Codiath
Codiath's Avatar
found this while looking to solve my own o2 sensor issues https://www.camaro5.com/forums/showthread.php?t=256493
Old 12-23-2018, 10:08 AM   #4
Artt
Drives: Red 2010 SS
codiath, the picture of the pigtail you posted is from the actual O2 sensor i believe. I need pics of the engine harness side. I also found the link you posted for the harness but cant find the same for the bank 2 sensor 1 side. Thanks for your help. If by chance you have pictures of your pig tails in the engine compartment bnak 1 sensor 1 and bank 2 sensor 1 from the back side where i can see the colors that would be a big help. Thanks again.
Old 12-23-2018, 11:17 PM   #5
Codiath
Codiath's Avatar
I hope you were able to get your issue all sorted out, but if not here is what I found using my car as reference. Bank 1 sensor 1 is driver side pre cat if I am correct, and bank 2 sensor 1 is passenger side pre cat. I might have missed a tracer but this should be enough info to get you wired up. I appears the only difference, side to side, is there is a grey wire in pin E on B1S1 and it is a green in pin E on B2S1.
bank 1 sensor 1
tan-pin A
purple/white-pin B
pink/black-pin D
grey-pin E
bank 2 sensor 1
tan-pin A
purple-pin B
pink/black-pin D
green-pin E
Old 12-24-2018, 12:40 AM   #6
Artt
Drives: Red 2010 SS
Perfect, thanks you, your b2s1 wires are the same as mine but the b1s1 i have a light green/wh for pin e. Im hoping the difference in color code is the year, mine is a 2010.
Old 12-24-2018, 12:41 AM   #7
Artt
Drives: Red 2010 SS
Looks like i'll be doing some soldering on Christmas Eve!! Thanks again
Old 12-24-2018, 12:47 AM   #8
Codiath
Codiath's Avatar
No problem, have fun and good luck. Merry Christmas eve.
Old 12-24-2018, 12:54 AM   #9
Codiath
Codiath's Avatar
Pics just for further clarification
Name:  B1S1 O2 sensor.jpg
Size:  147.7 KB B1S1 Name:  B2S1 O2 sensor.jpg
Size:  170.4 KB B2S1
Old 12-24-2018, 01:36 PM   #10
Artt
Drives: Red 2010 SS
Thanksagain for the pics, those are exactly what i was needing.
