JUICEDMOTORSPORTS
Old 06-08-2017, 09:24 PM   #1
anth331
anth331's Avatar
Drives: 18 Sierra Z71 13 1SS 18 CadillacXT5
Headers
I have a 2010 RS and I'd like to know, will headers make a big difference or just add a little more performance? I just installed a NPP exhaust so can I connect headers to my current exhaust? Pretty sure I would need a tune if I installed headers? Just trying to see if the money spent would be worth it. I don't need a race car just something that when I punch it it will move, it already does pretty good as a stock V6
anth331 is offline   Reply With Quote
Old 06-08-2017, 10:40 PM   #2
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Can't answer the NPP question but when I was N/A l, the headers were my favorite mod by far, big boost in performance. I have the ceramic coated BBK's and love them. A tune isn't mandatory but recommended. You'll get a CEL sooner or later without one.
Lil' Nasty is offline   Reply With Quote
Old 06-09-2017, 06:14 AM   #3
KillboyPowerhead
Drives: 2014 1LT RS
I watched a video by BBK and they showed a dyno chart proving something like a 30 HP gain just from long tube headers (everything else stock). The NPP is just a catback so there should be no issue tying in headers.
K&N Typhoon Cold Air Intake; Custom Cat-back Exhaust (w/ Magnaflow and Solo Performance); Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; Eibach Pro-Kit Springs; JPSS Delrin Radius Rod Bushing Inserts, Camber/Caster Bolts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings
KillboyPowerhead is offline   Reply With Quote
Old 06-09-2017, 06:15 AM   #4
anth331
anth331's Avatar
Thanks for the info
Old 07-29-2017, 09:26 AM   #5
PieNsky
PieNsky's Avatar
Drives: Victory Red 1LS
That ad was laughed at on here for quite some time.
Expect about 15 H.P. gain for long tubes. You will get a check engine light unless you have a tune to ignore your cat trouble code.
PieNsky is offline   Reply With Quote
