Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 09-18-2013, 06:24 AM   #1
rpepka
rpepka's Avatar
Drives: 2013 ZL1 # 2195
Put Continental 315/35zr20 On Rear Car Floating
I put 315/35ZR-20 Continental Extreme Contact DWS XL on rear and the car is floating. With the Goodyear's I could pull 1.2g's with these only .85 tops.
I am hoping they will firm up when a little tread wears off. So far not recommended.
rpepka is offline   Reply With Quote
Old 09-18-2013, 08:12 AM   #2
mmarx82
mmarx82's Avatar
Drives: '12 ZL1 #1609
Well it's an all season tire, might have been better if you lived up north during winter months. You can't beat a summer tire in the south. Continental's aren't known for performance either.
Life is too short to drive cars that suck.
My build Thread
mmarx82 is offline   Reply With Quote
Old 09-18-2013, 09:55 AM   #3
rpepka
rpepka's Avatar
I see what your saying, just have to burn the puppies off and get new ones!
Old 09-18-2013, 01:01 PM   #4
Joebot8484
ZL1 # 1307
Joebot8484's Avatar
Drives: 2012 Camaro ZL1, 2008 Hummzilla H3
Get it on video!
Click on my signature for my build thread
Joebot8484 is offline   Reply With Quote
Old 09-18-2013, 01:35 PM   #5
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
For our weather down here, I'm planning on trying a set of Invo's at the end of the month.
Old 09-18-2013, 02:56 PM   #6
Drew P
Drew P's Avatar
Drives: Camaro ZL1
Michelin SS or bust.
2012 A6 Coupe 630RWHP 10.93@125
Mods: ID850 Injectors; D3PE HX, Reservoir & Atmospheric Catch-Can; LPE 2.55 Upper & 9.1 Lower Pulleys w/ ATI Damper; LPE Idler Pulley Relocation Bracket; "Green" Serp. Belt; Cat delete;ADM Exhaust Override; Magnaflow X-Pipe Muffler (in addition to stock mufflers); Cold Air Inductions CAI; 160 thermostat; LS9 Isolator; Port/polish snout and intake runners; LPE GT9 camshaft with dual springs and titanium retainers; Kenne Bell BAP, Install and Engine Tune by Serious Hp; Fab work by D3 Performance Engineering; Trans Tune by Keith; Coming Soon: Flex Fuel Conversion.
Drew P is offline   Reply With Quote
Old 09-19-2013, 02:17 PM   #7
2014CamaroZL1
2014CamaroZL1's Avatar
Drives: 2014 CRT ZL1
It is an all season tire with much thinner sidewalls.
I found them bouncy on my Subaru STi.
To help the float situation, try adding a couple extra psi.
For the ZL1 they still are the best all-season option.
I will be getting a set soon for the cooler months.
But if you live in Florida, why run all-season tires ??
2014CamaroZL1 is offline   Reply With Quote
Old 09-19-2013, 06:02 PM   #8
SPOOKYGUNNER
ROCK
SPOOKYGUNNER's Avatar
Drives: 2013 ZL-1 TRIPLE BLACK VERT
CONTINENTAL
WHAT'S THE TREAD WEAR, TEMP RATING, TRACTION RATING?
GOODYEARS ARE 220 AA A
WHEN ONE AMERICAN IS NOT WORTHY TO BE FOUND...THEN WE AS AMERICANS HAVE LOST. POW/MIA YOU ARE NOT FORGOTTEN
SPOOKYGUNNER is offline   Reply With Quote
Old 09-22-2013, 03:56 AM   #9
rpepka
rpepka's Avatar
It has been raining very heavily in the afternoons one, two I was trying to save some $$$ those Goodyear's are pricy and wear out quickly.
Old 09-30-2013, 09:43 AM   #10
BenningJ
BenningJ's Avatar
Drives: 2013 AGM 1SS/RS LS3
I don't know how many miles you put on the tires yet but it could take up to 400 miles for them to break in. Tires do not have there full potential right off the bat.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts
BenningJ is offline   Reply With Quote
Old 10-01-2013, 02:20 PM   #11
djnice
djnice's Avatar
Drives: 13 ZL1 SIM, 99 Z28 Black
Mine grip good and no issues, but they had 3k miles wen I got them.
2018 C7 Z06 - WGG, M7. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
djnice is offline   Reply With Quote
