Old 05-13-2016, 09:49 AM   #1
Jayzmaro10
Jayzmaro10's Avatar
Drives: 2010 Camaro 2LT ABM #3678
Brembo's Brake issue
Hey guys I bought a used set of Brembo's. And I noticed one of the tubes that run from one side to the other has a small crack. I wanted to replace that tube any ideas if they sell it or is that something I need to have made? I have looked online for rebuild kits but nothing shows that particular part.
Jayzmaro10 is offline   Reply With Quote
Old 05-13-2016, 02:29 PM   #2
Chanman
Chanman's Avatar
Drives: '15 Camaro 2LS V6
I would suggest contacting GMpartsdirect.com and they should have your part.
Chanman is offline   Reply With Quote
Old 05-14-2016, 12:45 AM   #3
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
you could take it to a shop and have them make them cheap. I assume you dont have a flare tool or you wouldn't be asking. I highly doubt GM sells them separate as thay can be made at any shop cheaper than shipping.
JCunningham is offline   Reply With Quote
