Old 08-28-2016, 10:34 AM   #1
Jayzmaro10
Jayzmaro10's Avatar
Drives: 2010 Camaro 2LT ABM #3678
Sway bar issue with caliper (FIXED)
Ok so I just got done doing the FE4 switch over on my 2010. I am using the 1LE struts with Pedders linear springs. I have a ZL1 PFadt rear sway bar. I want to put my rear Brembos on but they don't have any room to mount. Any ideas? Has anyone else had this issue?
I swapped it to the 1LE sway bar. Problem fixed.
Jayzmaro10 is offline   Reply With Quote
Old 08-28-2016, 12:09 PM   #2
Jayzmaro10
Jayzmaro10's Avatar
Never mind figured it out can close this thread.
Old 08-28-2016, 12:31 PM   #3
Ppriyam
Drives: 2015 Convertible Camaro 1LT
how did you paint those calipers? i like the color and the finish.
Ppriyam is offline   Reply With Quote
Old 08-28-2016, 01:30 PM   #4
wrtowman
wrtowman's Avatar
Drives: 2011 Camaro 1SS
Perhaps add *FIXED* to the title and explain what you did to fix it. That way when someone searches for this problem down the road you will have helped out a fellow Camaro5 member.
2011 SGM Camaro 1SS/RS A6 - Vengeance Racing built/tuned. 590RWHP/560RWTQ, ADM LSA Conversion, 2.5 Grip-Tec, ZL1 fuel pump, ADM FPCM, FIC1000, VRPD2 Cam and LS3 Conversion with all the internal goodies, American Racing 1 7/8 Headers, no cats, SW Retro Cat Back, ADM Intake, AFCO HX, Varimax Pump, Rotofab Reservoir, B&M Transmission Cooler, VMAX TB, Elite Engineering CC, BMR LCAs, Trailing Arms, Toe Rods, DSS 1000hp axles, ZL1 Bumper and Sideskirts, Night Owl Halos, Matte Black 20" Rohana RC-22 with 20x10-275s/20x11-315s, R1 Concept Premier Drilled/Slotted Rotors, Hawk Ceramic Pads.
wrtowman is offline   Reply With Quote
Old 08-28-2016, 01:52 PM   #5
Jayzmaro10
Jayzmaro10's Avatar
They are shot with High Temp Cerakote. It's a custom mixed batch I made specifically to match my car. I absolutely love using it. It has natural repellant properties so keeping them clean is super easy.
Old 08-28-2016, 01:53 PM   #6
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
Unbolt the sway bar and bolt up the caliper then reattach the sway bar.
That looks to be how its done.
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28)
2009 Pontiac G8 3.6L the DD
102SS is offline   Reply With Quote
Old 08-28-2016, 01:54 PM   #7
102SS
waiting at the tree
102SS's Avatar
They do look nice
Old 08-28-2016, 02:39 PM   #8
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
How much heat can the cerakote handle!!!
Orange Krush II
Old 08-28-2016, 04:50 PM   #9
Jayzmaro10
Jayzmaro10's Avatar
1500 degrees.
Old 08-28-2016, 06:17 PM   #10
Jayzmaro10
Jayzmaro10's Avatar
