#Camaro6
BeckyD @ James Martin Chevy
Old 06-15-2022, 07:02 AM   #1
Darkside23
Drives: 2022 ZL1
Tie down method
Picked up a zl1 and need some advice on strapping this thing down to trailer it to get a clear bra installed, are there any holes in the frame to hook the strap too? I rather not go around the wheels and don’t have a E track on my trailer.
Darkside23 is offline   Reply With Quote
Old 06-16-2022, 07:20 AM   #2
ember1205
Hot Camaro
ember1205's Avatar
Drives: '20 2SS Convertible 6MT
Rent a U-Haul trailer. It will have the webbing that you can use for the front wheels. And, as long as you are traveling decent roads and not going "too far", it will sit nice and still without strapping anything down at the rear.
You will likely need some wood blocks or similar to drive the front wheels onto at the front of the trailer so that the splitter clears the trailer. I used 2x12's cut to about 18" in length so they wouldn't interfere with the web straps.
ember1205 is offline   Reply With Quote
Old 06-16-2022, 07:37 AM   #3
Bearded_Seamonkey
Bearded_Seamonkey's Avatar
Drives: 2022 ZL1 1LE
These are what I bought as my trailer also does not have etrack.
http://www.stranoparts.com/partdetai...397&ModelID=49
2022 Red Hot ZL1 1LE
1972 Chevy Nova
Sold: 1997 Z28 Camaro
2000 Corvette
Bearded_Seamonkey is offline   Reply With Quote
Old 06-16-2022, 10:22 AM   #4
closs2sx
closs2sx's Avatar
Drives: 1970 chevelle
I installed e-track in my trailer (it didn't have it originally) and I bought straps that go over the OD (outside diameter) of the tires and do not touch the car at all just the tires.
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car
2015 Z06 Z07
Daytona Sunrise Orange Metallic
Dads Car
2013 ZL1 vin 963
Crystal Red Tint Coat/Black Wheels
Exposed Carbon Fiber Insert
6 Spd Manual
closs2sx is offline   Reply With Quote
Old 06-16-2022, 11:01 AM   #5
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
u-haul...straps on the tires only
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 06-16-2022, 12:36 PM   #6
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Drives: Red Hot A10 ZL1 Convertible
The same way they do from the factory: Over the tires.
Of your trailer isn't set up for this. Get a better trailer.
Gunkk is online now   Reply With Quote
Old 06-16-2022, 12:39 PM   #7
Choda
Drives: Turbo 6.2
These are pretty cool. I use the A Arms and rear cradle. I was thinking about changing to not loading the suspension buy strapping to the wheels/tires.
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 06-16-2022, 10:40 PM   #8
cariboocreek
cariboocreek's Avatar
Drives: 2023 Corvette C8
I strap my cars down using an over the tire strap that attaches to my etrack. The strap attaches to the etrack at the very back of the tire, over the tire and again through an idler attachment at the very front of the tire that attaches again to the etrack. The idler attachment allows for tying down extremely low vehicles. Manual transmission cars should be hauled in neutral with the park brake set and autos in park with the park brake set.
No etrack is going to make it more difficult and will likely require a through the wheel tie down strap which can be tied to either tie down rings front and back or to other corner tie downs.
2023 Corvette C8 70th Anniversary Edition
———Gone But Not Forgotten———
2022 Camaro ZL1 Convertible (Never Delivered and won’t forget)
2019 Camaro SS Convertible
2019 Corvette Grand Sport Convertible
2013 Corvette Grand Sport
2013 Challenger SRT 392
1995 Camaro Z28
cariboocreek is offline   Reply With Quote
Old 06-17-2022, 05:24 AM   #9
Darkside23
Drives: 2022 ZL1
I just worry pulling the car out of alignment doing it this way , really sucks there’s no holes in the frame to tie to with a I hook.
Old 06-17-2022, 06:38 AM   #10
cariboocreek
Hauled cars for years with over the tire straps and have never heard of or seen a car that had been pulled out of alignment because of tire straps. I do center the strap on the etrack so any force is directly forward or directly rearward.
Hauling a car requires the right trailer, the correct setup, and the proper equipment. Otherwise….
1995 Camaro Z28
Old 06-17-2022, 07:05 AM   #11
ember1205
Hot Camaro
ember1205's Avatar
I got the sense from your original post that this was a one-off situation. Your comment here seems more in line with long-term trailering needs. You've gotten responses that are all over the map in terms of one-time versus long-term trailering needs...
If you need to trailer once, rent the U-Haul. You won't be driving that far and there will be zero issues that arise from hauling it like that. If you're looking for something to drag the car to the track repeatedly, then it seems you may need to be looking for a different trailer or at least a different setup on the one you have.
Old 06-17-2022, 04:17 PM   #12
Darkside23
Drives: 2022 ZL1
For sure over the tire is definitely the way to go I was talking more in the limes of through the wheel and back to the tie down to the trailer which I think would cause too much reward or forward stress on the components
Old 06-17-2022, 07:28 PM   #13
cariboocreek
Agreed. Tying down using the wheels/tires as contact points should be done with straight ahead and straight behind tie down points.
1995 Camaro Z28
Old 04-04-2023, 08:59 AM   #14
PowerDemon
PowerDemon's Avatar
Drives: Camaro ZL1, Golf GTI
Nice! Did you have any rock chips? I would be towing mine with an F450 and I am wondering if I should buy one of those big rock guards that goes on the hitch.
How was the door clearance with the fender folded down?
’22 ZL1 Riverside Blue 6MT
’15 GTI Carbon Steel 6MT
PowerDemon is offline   Reply With Quote
