07-19-2020, 09:10 PM | #1 |
Drives: 2010ss M6 LS3 Join Date: Jun 2018
Road track racing tire size? 2010 SS
Good day fellas, ive had my 2010 SS at road racing track a few times (Castrol in Edmonton Canada) and decided to buy a second set of rims and tires just for track days.
What is the best recommended tire size to use for track road racing? I heard guys running same size all around?? I do have some track susp mods: sway bars/all Poly bushings/ tail arms/toe arms/ front castor plates/springs/shocks/brakes. have a street/track alignment (have to look up my specs). Having issues with the search feature, so thought I would post. Thanks, Guys |
07-19-2020, 09:21 PM | #2 |
PS: im was considering either Bridgestone Potenza RE-71R (available sizes:
255/40R20 245/35R20 295/30R20 285/35R20 or the Nankang AR-1 ,available sizes: 245/35ZR20
265/35ZR20 285/35ZR20 305/30ZR20 |
07-19-2020, 09:30 PM | #3 |
Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
Square setup is preferred for tracking.
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
07-19-2020, 10:32 PM | #4 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
i would go with a square setup and possibly 19s or 18s for wheels
Sent from my SM-G975U using Tapatalk
Bone Stock |
07-20-2020, 01:18 AM | #5 |
thanks, 69fordkiller why not 20? thought thinner side walls and 20" rims easier to find.
07-20-2020, 01:21 AM | #6 |
Seems like square setup is best, so what SIZE you guys think?? what fits square? Maybe:
255/40R20? 265/35ZR20? my Elb springs are 1.5" lower and was looking at factory used wheels (but could try find aftermarkets).'Thanks again |
07-20-2020, 08:05 AM | #7 |
What are your wheel sizes your putting the tires on?
07-25-2020, 04:53 PM | #8 |
Rons1LE I was looking at getting the factory 2010 SS rims but use all rears only so 9.5" wide I believe
07-26-2020, 11:21 AM | #9 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Use a 10 in the front and 11 in the rear and an go 285 or 295 square. Diameter is up to you.
Orange Krush II
