View Poll Results: Horse Power at Crank | |||
800 - 825 Horse Power | 0 | 0% | |
826 - 850 Horse Power | 1 | 16.67% | |
851 - 875 Horse Power | 0 | 0% | |
876 - 900 Horse Power | 0 | 0% | |
901 - 925 Horse Power | 1 | 16.67% | |
926 - 950 Horse Power | 1 | 16.67% | |
951 - 975 Horse Power | 0 | 0% | |
976 - 1000 Horse Power | 1 | 16.67% | |
1000+ Horse Power | 1 | 16.67% | |
Good forbid - Engine Failure... | 1 | 16.67% | |
Voters: 6. You may not vote on this poll |
Thread Tools |
10-13-2023, 02:38 AM | #435 | |
1000hp is NEVER Enough!
Whoa Baby!
Relearning clutch feathering and release rpm's to keep traction!!!
1,000hp IS NEVER ENOUGH!!!
10-13-2023, 02:42 AM | #436 |
ACARS Gauge Assy
Okay, So I sent an e-mail to Acars about the gauge cluster as my HUD has a large "P" on it and my miles per hour only displays "0". I am sure I just have to input a code to fix it.
10-13-2023, 02:54 AM | #437 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I bet it's a handful to say the least.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
10-13-2023, 08:39 PM | #438 |
Uncontrolable Wheel Spin
Every time I take off from a stop or apply gas after shifting, I have to be gentle on the pedal. Even with the 315's on the back it easily spins the tires at any speed!
Drive train is smooth and vibration free. No vibs in stick shift, just road noise, I-5 around Seattle is so rough, like A-10's have strafed it!
10-18-2023, 11:57 PM | #439 |
Almost done!
Fixed oil leak, 3 of the 4 screws on the shut off valve assembly were loose for the accumulator. Went ahead and installed new fittings since I had it out. Also got the battery kill switch handle installed, got the switch cover fitted / installed.
10-19-2023, 12:05 AM | #440 |
Just a few more things
Got to install parachute onto mount, notch lower pan for headers. And a couple of other little things....
I have an air bag light on dash but made up a harness for the race seat (so more trouble shooting). The new gauge set does not display mph on HUD nor the does the G-force meter work (and more trouble shooting, working with vendor).
10-19-2023, 03:00 PM | #441 |
Driving Vids
Okay, sorry for the delay, here are the links to the drive by vids. Inside vids to come...
It does not come across in the vids but the supercharger whine is superb!!! https://youtube.com/shorts/gImQ27ZebgU https://youtube.com/shorts/8wVBY_uvcRI https://youtube.com/shorts/lZ7JZNdrh3o https://youtube.com/shorts/r5WNTooVUnc https://youtube.com/shorts/rak-7IdLv-U Side note vendor for the digital gauge got the speed to display on the HUD, but the HUD shows a "P" in gear. The car and everything should be ready to run the Arkansas mile this spring. It is my goal to go 220mph in the standing mile. I also want to take it to the Pacific Raceways drag strip in Kent to see what it will do in the 1/4 mile. I am in no way a pro at this stuff having never done it, but hope to have family there to make it a fun family day.
10-26-2023, 06:11 PM | #442 |
Kill Switch
Well, Bummer...
I have to change out my kill switch. The 2 pole single throw will not kill / seperate the alternator from the rest of the car. Ordered a 4 pole dual throw switch. Moroso P/N: 74108 I should be able to re-use the push handle and mount brkt for the new switch. I also ordered a new OEM H/D, ZL1 / Z28 transmission mount P/N: 20952439 (with green lable) and the Rev Shift Polyurethane Trans Mount Insert. I also bought a clutch pedal stop, I do not like the feeling I maybe over stroking the pressure plate. Have to find out where the starter needs the clutch pedal to be for starting the car. I can disable the clutch pedal start in HP Tuners, but would rather leave it on. (UPDATE: THIS PEDAL STOP DOES NOT WORK)
10-26-2023, 07:40 PM | #443 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
I am curious How different the Trans mount is, please post back, I do have the rev shift insert sitting on the shelf haven't installed it yet.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
10-26-2023, 07:57 PM | #444 |
I will let you know. Right now all I get is road noise through the stick shift, drive train is smooth. I will try to compare the way it feels.
10-26-2023, 08:00 PM | #445 |
I just did a little research and supposedly my14 SS may have this mount from factory. I didn't pay attention when I was under there. Great build.
10-26-2023, 08:27 PM | #446 |
Thank You!
10-27-2023, 07:55 PM | #447 |
The car sounds very good Vic! It's really nice to see a great build like yours come together. Thanks for sharing your build with us and I'm sure you'll reach a goal.
10-31-2023, 10:20 PM | #448 | |
Was not ignoring your input, I was laid up with COVID again, my 3rd time. Finally going back to work tonight (nope, maybe tomorrow).
