05-19-2018, 07:32 AM | #1 |
Drives: 2013 IOM 2SS Join Date: Apr 2013
Uneven Brake Pad Wear
2013 Camaro SS, ~44,000 miles. I had been noticing some noises and strange feeling in the pedal so I checked my brake pads. On the right front Brembo, the inner pad is worn quite a bit more than the outer pad. Any ideas on what could cause this? Seems like the inner pad was sticking maybe? I'm going to bleed it, but is there anything else I should do as I put everything back together with new front pads and rotor?
Ordered 4/24/2013...Built week of 5/13/13...Delivered 6/7/13
2013 Inferno Orange Metallic Chevrolet Camaro 2SS/RS 6.2L V8, NPP, Manual 6-Speed, GM Performance Shifter, Cold Air Inductions CAI, Bo White's Stage III Ported TB, Sunroof, Window Tint, Gen5DIY Halo & DRL Harnesses, 5000k LED DRL Bulbs, APEX Skip Shift Eliminator, Hood Spears / Front & Rear Blackout Panels / Gills from Big Worm Graphix, Gary's Customz Front & Rear Painted Bowties, Powdercoated Wheels & Camaro Badges, Painted Calipers, Plastidipped Taillight Bezels |
05-19-2018, 08:48 AM | #2 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
before bleeding do this...http://www.rangeracceleration.com/Clutch_Care.html
get all that nasty clutch dust fluid out first BEFORE doing a 4 corner bleed....and remember...our cars brake system is setup in x pattern... so right rear then left front..then left r and r front.....inner pistons first...I use a hand held vac pump and pull at least an oz or more until the new fluid is pulled thru.. now this does not flush the ABS so you can either go out after and do some high speed brake lockups to get the system to pulse or gonna need a tech II...good luck! peace btw - have the rotors checked and/or turned...since I use stock type replacement I usually replace the rotors and pads as a set...and when you compress the caliper pistons u can usually tell if it's stickin....l8tr
05-19-2018, 11:43 AM | #3 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
The inner pad is receiving more pressure from the pistons as they are being pushed out. I don't think this is very unusual. That said, mine have worn more evenly.
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
05-19-2018, 05:24 PM | #4 |
Drives: 2015 Camaro 1SS 6M Join Date: Dec 2017
Clean everything and use a good high temp anti seize to lube the pins when you re assemble. This is not uncommon and is much more likely to be due to dirty pins and contact points than stuck caliper pistons, check for any type of ridge or damage on your sliding points.
