Old 10-07-2013, 03:07 PM   #1
Gagootz78
Gagootz78's Avatar
Drives: 2010 2SS Camaro
Do I need an alignment after Pfadt rear tie rod and rear trail arm kit?
Am I going to need an alignment after the Pfadt
Rear kit. The shop I bought the kit from told me No and the shop that is going to install the kit said yes. Just trying to get a correct answer.
Gagootz78 is offline   Reply With Quote
Old 10-07-2013, 03:09 PM   #2
TXM62SS
TXM62SS's Avatar
Drives: 2012 2SS/RS LS3
It is recommended. I had the same kit installed a month ago and went for the alignment.
Victory Red 2012 2SS/RS LS3 Camaro
Pat G. Spec Cam from Cam Motion 228/236 .599/.599 112+2LSA
Kooks 1-7/8" LTs w/ Cats
Roto-Fab, Bo White TB, Borla Touring Catback
Texas Speed UD Pulley
3.91 1LE Gears, MGW
Tuned by Pat G
TXM62SS is offline   Reply With Quote
Old 10-07-2013, 04:41 PM   #3
Gagootz78
Gagootz78's Avatar
Ok sounds good I'll just get one after it's installed. Thanks.
By the way how do you like the kit?
Did you notice a difference after it was installed?
Old 10-07-2013, 09:27 PM   #4
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
The toe link has a plain bolt on one end and the toe adjusting eccentric on the other end. If the technician marked the eccentric theoretically the alignment would be unchanged. In theory. If one of the toe links was tweaked from a bad bump, your alignment is off. If the OE am is slightly different in length on center your alignment is off. You alignment may not have been spot on when you changed the parts. When you do suspension work on an IRS car, an alignment is in order.
Old 10-08-2013, 10:08 AM   #5
camaro500
camaro500's Avatar
Drives: 2017 Jaguar F Type R Tuned 498awhp
absolutely needed
JRE cammed w.full bolt ons 444rwhp/422rwtq SOLD
''Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.'' - F. Bueller
camaro500 is offline   Reply With Quote
Old 10-08-2013, 02:13 PM   #6
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Yes, I would definitely recommend an alignment afterward.
Best regards,
Tyler
888-308-6007
Old 10-08-2013, 02:33 PM   #7
Gagootz78
Gagootz78's Avatar
Thanks guys for the input. I'm definitely getting it done. Redline Motorsports is doing the install and there is a shop right across the street that is going to do the alignment right after. Couldn't of worked out any better.
