10-28-2012, 09:42 AM | #1 |
Drives: 2011 Camaro 1SS/RS LS3 Join Date: Apr 2012
Barton Option 1 Installed
I had the Tri-Ax previously. Put 25K miles on it. I have good things to say about that one, however it always rattled above 3K RPM from the day I installed it. Figured it must have been a short coming of the design. I am wrong about that, here is why.
So I bought the Barton, which has even a shorter throw (like) and looks fantastic. HOWEVER, it is still rattling. I have deduced that it is the factory cotter pins that hold the shaft to the linkage. It's the only moveable part that has any play....even if it is slight. That must be what is rattling. Anyone have suggestions about the above^? There was nothing wrong with the Tri-Ax, nor is their with the Barton, they have the same symptom of rattling. Any one done anything special? |
10-28-2012, 09:47 AM | #2 |
I attached picture with the first post, don't know why it didn't attach. Happens very often on this site when I try to upload pictures.
10-28-2012, 10:16 AM | #3 |
Drives: 2010 Cyber Grey Metallic 2SS/RS M6 Join Date: Nov 2009
I've had my barton installed almost for the entire time I've owned the car (20,000 miles) and it doesn't rattle at all. Or if it does, I just haven't noticed it.
I have heard others talk about their rattling shifters though (various manufacturers: hurst, barton, etc....). |
10-28-2012, 10:24 AM | #4 | |
I think it has something to do with the cotter pins (clips) that hold the shaft through the linkage. There's a mm play side to side. I thought about wrapping it in dental floss between pins and linkage to create barrier or pillow (hacky) Putting feelers out there. |
10-28-2012, 10:27 AM | #5 |
It shifts great and tight. Doesn't make any noise at lower RPMs. Only when you get on it.
10-28-2012, 10:33 AM | #6 | |
Do you have any video of the rattling? Maybe mine does it too and I just haven't paid attention. lol. The linkage pin that holds the shifter in is held in place by two c clips correct? This could be the source of the rattling. I would try your dental floss trick, or maybe even some pipe thread tape? This has nothing to do with it, but I had to zip tie my e-brake cable to keep them from rubbing on the inside lip of my Forgeline wheels. Sometimes you just have to use some "garage fixes" for things. lol. |
10-28-2012, 11:07 AM | #7 |
WFO all the way
Drives: Hyper Blue 2SS, Kalahari, 6 speed Join Date: Aug 2009
My Barton also rattles horribly, very noticale and yes it is installed correctly. swapping the plastic GMPP shifterknob for a very heavy steel/chrome 2" one made it much quieter but still noticible. It make noise while driving if you try to move it and is most pronounced just below 3000. I do like the feel, but not that it sits 2 inches taller than the factory knob.I will try some padding below the boot next
2016 2SS -no mods
10-28-2012, 11:14 AM | #8 |
I had padding under the tri-ax, didn't change decibel roar/racket. the metallic racket travels up the stick like a tuning fork.
Posted from Camaro5.com App for Android |
10-28-2012, 11:16 AM | #9 |
Ill video today when i'm out and about.
10-28-2012, 11:41 AM | #10 |
Drives: SIM Join Date: Jun 2010
My barton short throw rattles when I really get on the car, above 3K rpms or so. I installed it correctly as well. I did notice that if I hold the shifter in gear with my hand while accelerating it doesn't rattle at all? It only rattles when I shift it in a gear and take my hand away while accelerating.
10-28-2012, 01:42 PM | #11 | |
Probably go the route of pipe tape AND dental floss. It has wax on it, both sound temporary. |
10-28-2012, 02:38 PM | #12 |
Mine rattled quite a bit when I first installed it, mostly in higher RPMs in 2nd and 3rd gear. I tried the teflon tape on the shaft and knob threads first. Then I wrapped dynamat around the shift linkage and the lower part of the shaft (the part under the boot). Now the rattles are 90% gone. I have to really get on it to hear anything at all.
10-29-2012, 06:18 AM | #13 | |
Sound and Video Barton Rattle
I'm going about 65 in 4th with foot off accelerator, then I get on it.
10-30-2012, 03:46 PM | #14 | ||
Drives: 2SS/RS M6 Join Date: May 2012
Since the MGW is the whole shifting assembly vs the Hurst and Barton is just the shaft, i feel like the MGW wouldnt do this rattling. The stock shifter already flops around a lot when going over bumpy roads. Thats why i think the Hurst and the Barton rattle like this. Either way, that is no excuse for an aftermarket part worth $200-$250 to do this. There should be a fix by the manufacturer... Not us guys trying to jerry rig stuff together to make up for lack manufaturer testing Even though the MGW is 350+ a knob, id rather have no play and or rattling |
