Old 07-31-2013, 03:29 PM   #1
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Changing the tranny fluid at 30,000?
I am a lil bit under 30,000 and i am looking into changing some fluids. Should the tranny be changed at this marker? I have grinding going into second occasionally and RP synchromesh sounds like a good option right about now..
Any suggestions?
Nighthawk89 is offline   Reply With Quote
Old 07-31-2013, 05:40 PM   #2
Mouse6.2
Mouse6.2's Avatar
Drives: 2013 2SS/RS M6 NPP
Now would be a good time to change out the fluid. It is super easy to accomplish. Others have notices better shifting when moving to Royal Purple, Mobil 1 and AMSOIL.
Mouse6.2 is offline   Reply With Quote
Old 07-31-2013, 06:57 PM   #3
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Allot of guys using Red Line D4 also and getting good results. That is what I am probably going to due next month.
Scott@Bjorn3D is offline   Reply With Quote
Old 07-31-2013, 07:03 PM   #4
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Any suggestions?
The suggested interval is every 50k miles however if you're getting a grinding noise go ahead and change it and see if it goes away.
Old 08-07-2013, 01:57 AM   #5
LIM3
it's mind bottling..
LIM3's Avatar
Drives: SGM
Is there a DIY on this ?
Old 08-07-2013, 04:37 AM   #6
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Manual or auto?
The manual is pretty easy and I would be surprised if there wasn't one. The auto isn't exactly DIY-able as it pretty much requires a lift.
Old 08-07-2013, 09:29 AM   #7
LIM3
LIM3's Avatar
Drives: SGM
Originally Posted by Mr_Draco View Post
Manual or auto?
Well I'm an auto so I'm screwed. Thanks man
Old 08-07-2013, 11:06 AM   #8
Nighthawk89
I just ordered my Royal purple synchromax and 75w90 rear diff fluid as well as the JPD separate brake/clutch res and 4 bottles of motul!
