08-05-2013, 07:16 PM | #1 |
Drives: 2013 Camaro 2SS RDP Tuned L99 Join Date: Apr 2013
How/When to Properly Check Engine Oil on L99?
Like the title says.... I checked the oil in my L99 yesterday with about 4100 miles or so on it a couple hours after shutting it off. It appeared to be down to about half on the hash marks on the dipstick so I added maybe a half liter to bring it back up.
I pull the dipstick tonight cold (car hasn't ran today at all) & it is about a 1/4 inch past the high mark. So my question is how do you properly check the oil in the L99 hot or cold? Do I have too much oil in there now that I should be concerned about? The car does use a little it seems but it is still new too. I planned on getting its first oil change this week anyways figured I didn't want to go much past 7000 km or 4500ish miles. I appreciate anyones recommendations or experience. Cheers, Cam |
08-05-2013, 07:18 PM | #2 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
I check mine cold and look for a reading that is between the marks, until it's at the lower mark, I don't put any in.
08-05-2013, 07:19 PM | #3 |
Drives: 2010 Camaro SS Join Date: Jul 2012
The oil level is fine if it is in the hash marked area in the dipstick when it has sat not running. You over filled it guy, you should have read your owners manuel.
2010 Camaro SS
Black/IOM |
08-05-2013, 07:24 PM | #4 |
Drives: '12SS/2SS/45TH-'06 2500HD/Silverado Join Date: Jul 2012
Should be between the hash marks cold. Above the top of the hash is too much. I believe at the bottom of the hash is 1 quart low, not sure how much overfilled 1/4 inch over the hash is, but it's definitely over...4100 miles, definitely due for it's first change!
08-05-2013, 07:57 PM | #5 |
Let's go Rangers!
These cars like to run on the lower end of the stick, it calls for 8qts but I usually put a bit less, some people actually only put 7qts.
Ideal level is mid hash marks when cold (that mid indent), low line of the hash mark when hot. Try not to run near the top line if possible, it not needed. Sounds to me you are now overfilled and that is worse then under filled especially with the L99 lifters. Get under there and drain some oil. Also if you broke the car in properly and got the rings seated correctly you should have ZERO oil burn. I beat my car off the lot with 18 miles and my oil level has yet to change and I drive hard. My mpg avg is about 13. Sent from my 2SS/RS Last edited by nyrfan; 08-05-2013 at 08:10 PM. |
08-05-2013, 08:44 PM | #6 |
Guys thx for the replies. I thought I had read the owners manual about checking the oil a while back. I have not driven it at all since doing this so it wouldn't hurt anything yet. I'll see if I can drop some out somehow tomorrow night. Car won't be driven anyways or just take it & get it changed out right away?
The manual says to check it a few minutes after shutting it off actually but not to fill past the hash marks either which initially I didn't think I had doh!!! I'm not sure I will be able to get under this car to drain some but if not I'll just get it changed right away. Gonna call the dealer in the AM I wouldn't say it is really using oil & I don't know if I set the the rings or not. I was mostly easy on the during breakin but did dial it a few times too. But from now on I will only check the oil cold to be safe. Cam |
08-05-2013, 08:46 PM | #7 | |
08-05-2013, 08:57 PM | #8 |
I assume I can reach the pan plug without jacking the car to drain a little oil out? I guess in hindsight if the car didn't really need the half liter it hasn't burned any either if I need to take it back out LOL.
Cam |
08-05-2013, 10:23 PM | #9 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
No need to drain any off.........you'll be fine. And you should check it more often.......at least once a week, bare minimum.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
08-06-2013, 06:25 AM | #10 | |
Thx all. Cam |
08-06-2013, 06:37 AM | #11 |
Banned
Drives: 2011 Chevy Camaro Join Date: Sep 2010
Best time to check oil is first thing in the am after the car has been sitting all night.
08-06-2013, 08:20 AM | #12 | |
Drives: 2013 Camaro 2LT/RS Join Date: Jul 2013
I usually pull mine cold too but if I need to check during the day after driving it a while I will wait for at least an easy hour to allow as much oil to drain down. When the oil is hot your oil is much more fluid so checking when it's cold guarantees all the oil is at the bottom. When you do check I wouldn't add any oil unless your an easy quart low. That way it's much easier for you to gauge how much oil is needed. I also thing frequency is the main key here. I'd check once per month once your sure your motor consumes oil as most engines do that easy. Don't wait for that perverbial engine tick like I did in my 08' Impala SS. For myself I learned something about my own motor after witnessing this. Mail Clerk |
08-06-2013, 12:16 PM | #13 | |
Cam |
08-06-2013, 12:38 PM | #14 |
Drives: #1 CAMARO FAN Join Date: Nov 2011
If you are at 4,100 miles it's time for your first oil and filter change.
