07-25-2013, 04:48 PM | #1 |
Bullydog as an add-on to a dyno tune?
I run a Cobra Fi2000 PowrPro module on my H-D Streetglide and just love the way it 'fine' tunes the air/fuel ratio for the modified intake and exhaust that I have on the bike. I know for a fact that it's improved my mpg, low rpm acceleration and made the engine run less lean at low rpm.
I also understand how this works on a bike because there are 2 O2 sensors and 2 injectors making it possible to continuously adjust the fuel delivery on every injection cycle. But a car is a whole different can of worms, however I believe the same is possible in theory, if the O2 sensor is constantly read then a system like Bullydog's GT should be able to adjust the fuel delivery on the spot. I know that a custom tune is the best way to go for a car and I will certainly have it done, but what about having the Bullydog piggy-bag on top of the custom tune to make those small adjustment needed due to atmospheric changes that a 'fixed' tune cannot take into account? Would it work? Does it make sense? Or am I just |
07-25-2013, 05:10 PM | #2 | |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
07-25-2013, 05:23 PM | #3 |
@axis thanks for that info!
Didn't know that the O2 sensors and PCM were 'flexible' enough to handle CAI & Headers on their own. |
07-25-2013, 05:54 PM | #4 |
Search Ninja
Absolutely they can. You will throw a cat efficiency code with LT's but that's just the rear O2 sensors telling the PCM that the cats aren't working correctly. We have 4 O2 sensors. The rear ones play no part in tuning. In fact, when you get LT's and a tune, they turn the rear ones completely off so there's no issues with the PCM waiting for information from them. This keeps them from failing a OBD port inspection.
Tags |
bullydog, tune |
