07-05-2020, 08:47 AM | #1 |
Drives: 13camaroZL1v,06 911, 18 StingerGT2 Join Date: Apr 2020
Exhaust - Stock or Something Aftermarket
This may be a neewb question but my 13 ZL1 convertible has exhaust that appears to be stock. But is it always supposed to be so loud, or did the PO possibly do something?
I had a 2011 vet that I installed a switch on so that you could open or close the flaps in the exhaust manually. Normally it would only open up when you got on it hard. Is the ZL1 the same? If so, what should I look for as sometimes I would like to quiet it down some. Maybe a fuse pulled, or a button hidden somewhere? |
07-05-2020, 09:48 AM | #2 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
Previous owner could have pulled the NPP vacuum fuse switch in the trunk, or could be modded with a mild to wild switch that does the same. |
07-05-2020, 09:53 AM | #3 |
Drives: 2013 ZL1 Camaro Join Date: Feb 2018
There is a fuse box in the trunk behind the liner on the right side. #8 fuse controls the flaps. If it's pulled the flaps will be open all the time. Many people pull it. With fuse in place the flaps will be open at idle and above 3500 rpm. Closed between.
IF I remember correctly. |
07-05-2020, 09:58 AM | #4 |
Thanks so much!! I bet the fuse is pulled. It does sound pretty cool, though..hehe..
07-05-2020, 10:17 AM | #5 |
Ok, so I went and found 2 remotes in the glove box in a plastic bag. Mild to wild remotes they appear to be.. lol.
I started it up and tried them just idling and didn't really notice any difference. I'll take it for a rip later and see what's what. Man, I just keep finding nice little add ons to this thing. |
07-05-2020, 11:43 AM | #6 | |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
UPSTATE C5 MEMBER
07-05-2020, 11:45 AM | #7 |
Yep.. just like my 2011 Corvette did. Nice. I what other goodies I'll find installed lol.. I hoped maybe a solid isolator but it does rattle a little at idle.. not all the time though.
07-18-2020, 11:37 AM | #8 |
With LT's and no cats, these cars do sound good with the stock H pipe and catback.
FBO. Cammed. Flex fuel.801whp/741wtq on e85
