12-14-2018, 05:16 PM | #1 |
Drives: 2010 Camaro SS A6 Join Date: Oct 2018
New VMAX T.B arrived
Just got my new VMAX T.B today. I just read a blog from someone mentioning that you should not use the original gasket when replacing your throttle body. Is this true for the most part or do you guys think it's o.k to use the factory one?
12-14-2018, 06:02 PM | #2 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
I reused my factory one, as it looked good. The bolts don't need to be very tight either.
More to come. |
12-15-2018, 01:33 AM | #3 |
Ive reused the one on my SS probably 200 times. Still good with 150k miles on it.
12-15-2018, 10:42 AM | #4 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Reused mine , no problem
OLD GUY FLYING FAST AND LOW
12-15-2018, 10:53 AM | #5 |
No reason to buy a new TB gasket. Most LS gaskets are reusable, just make sure they don't look torn or it poor shape. Then toss on that V-max TB and make some easy power. We've had good success with them.
12-15-2018, 01:26 PM | #6 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
Yep...use the old one..its fine.
