12-18-2018, 06:35 PM | #1 |
Drives: 2013 ZL1 Join Date: Jul 2017
ZL1 lower Black front and side skirts have white spots
What are you guys using to keep your lower front and side skirts Black. Mine have some white/gray spots and nothing I use helps turn it back to black.
Thanks for the help. |
12-19-2018, 12:30 PM | #2 |
Instagram: Sangstah
Mother Back to Black works wonders on plastics.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
12-23-2018, 12:15 AM | #3 |
Thx
12-23-2018, 07:25 AM | #4 |
Drives: 2015 Z/22 Join Date: Aug 2015
A word about Mothers Back to Black - it is just a coating, it doesn't actually clean/fix anything. I tried this stuff on my vinyl stripes, and although it looks great at first, after each wash the stuff comes off and after a few washes the stripes are back to crap.
12-24-2018, 10:28 AM | #5 | |
Any idea what fixes it???? Looks like oxidation.
12-26-2018, 08:31 AM | #6 |
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ Join Date: Dec 2010
Any back to black product will fix it (Back to Black, VLR, etc.). It is the nature of the material. Some people don't mind the dry look of the plastic, while others don't like the look that much. It goes without saying that you should avoid putting any wax or polish product on the plastic parts.
I only need to apply the dressing once a year on my lower skirt and chin spoiler. I like VLR personally. This product smells nice and it seems to last.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic '15 Malibu LTZ 2LZ Turbo '14 CAMARO ZL1 Blue Ray Metallic |
