09-03-2010, 06:42 PM | #1 |
Pirelli P-Zero Nero tire pressure
Can anyone that has Pirelli P-Zero Neros tell me what tire pressure you are using for the following sizes:
305/30Z22 105Y & 265/30ZR22 97Y Thanks
YOU DON'T JUST PARK IT..... YOU DISPLAY IT |
08-13-2011, 06:50 AM | #2 |
did u ever get an answer to this? im running into the same issue right now...
SHOCKWAVE - 2SS/RS/M6 - Blk/Blk
JRE Tuned - ARH LT 1-7/8 w/Cats - JRE Rear 4.11 - Borla "S" Cat-Back - CAI by CAI - H&R drop - HURST Shifter - BMR Tunnel Brace; 4 Point Brace; Adjustable Toe Rod; Rear Trailing Arms - Sphon Control Arms - MTI Racing w/Fire Sleeves - Stealth Ambers - GTS Tails - Phantom Grille - Concept LED Sidemarkers - Blacked out logos - Hotchkis Bars & End links - BMR Front Driveshaft Loop (install soon) - BMR Subframe connectors (install soon) http://www.cardomain.com/ride/3813191# |
Similar Threads | ||||
Tire Sealant Kit - Warranty Issues | jbreed | Wheels and Tires Talk Sponsored by The Tire Rack | 38 | 09-14-2011 02:18 PM |
Tire pressure monitor CEL after tire change | B.Buster | Wheels and Tires Talk Sponsored by The Tire Rack | 6 | 04-01-2010 08:45 PM |
now logging actual line pressure in A6, less than 100psi in 3rd | parish8 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 0 | 02-20-2010 09:46 PM |
Tire Pressure Monitoring | Dentyneice | Wheels and Tires Talk Sponsored by The Tire Rack | 8 | 08-14-2009 06:42 AM |
I think i'm done waiting. | pinkcamaro10 | Off-topic Discussions | 332 | 05-13-2009 04:56 PM |
