07-01-2020, 02:59 PM | #1 |
Drives: 2010 Camaro SS Join Date: Jun 2020
What can I expect from a tuning?
I'm a noob when it comes to electronics and software in cars. Then again I'm not much of a pro with hardware either. I've been thinking of getting my car tuned for awhile but I am uncertain as to what I can expect in the future should I decide to do it. The only reason I am considering getting it tuned is for the LT headers or just high flow cats. From what I've read not tuning it will cause a CEL if either of these two things are installed. Since this is my daily driver I really I am really looking to keep this long term without compromising the engine. My question is if I tune the car will I be putting the engine under more "stress" causing it to shorten its life? Maybe I'm looking at it the wrong way, I'm almost associating it to installing a turbo but I may be wrong.
07-01-2020, 03:53 PM | #2 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
You will not be putting the engine under more stress, other than the better it runs, the more power you will get if you put your foot in it. It's more likely to have problems if it's not properly tuned, especially if its running lean.
07-01-2020, 05:32 PM | #3 |
Drives: 2010 2SS/RS A6 Join Date: Aug 2019
You can expect a nice increase in power. I purchased my headers and tune from Dynosteve and it really woke up my L99. You will not regret the headers or the tune. If you are looking in NC I have talked with SSLSX about cam and dyno and they seem really on top of things.
2010 2SS/RS
CAI Intake Phastek Air Scoop Kooks w/ HF Cats Corsa Sport DynoSteve Tune |
07-01-2020, 06:43 PM | #4 |
Thank you both for the info. I think I need to look more into this but I'm starting to feel more comfortable with tuning it. I can't say I've read any negative things about tuning so far.
07-02-2020, 06:58 AM | #5 |
Think of tuning as optimizing. Every time you make a hardware adjustment (headers, intake, cams) it changes the air flow and/or fuel delivery. Tuning it just re-balances the air/fuel delivery and spark timing so you are getting optimal combustion.
2010 Camaro 2SS
2018 Charger GT+ 2005 Cavailer LS S/C - Sold '87 HD FXRT - Wrecked pending repair |
07-02-2020, 08:07 AM | #6 |
That makes sense, from my reading there are different levels of tuning some more mild than others.
07-02-2020, 02:57 PM | #7 |
Yea when you start pushing for higher levels of power and putting more aggressive parts on you can opt to get more bang out of it with more aggressive spark for example, or dial it back a touch for safety. On the same thread though, you can keep the build reliable if your approaching the mechanical limit, of the valve train lets say, by upgrading the springs or what have you. So the long and short is you're tuned within the mechanical limits of your build. Any credible shop that provides tuning services will do this by nature.
2010 Camaro 2SS
07-02-2020, 06:35 PM | #8 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Plus most tuners like DynoSteve here will tune it for daily driving. It’s not as a aggressive tune as a drag car.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
07-03-2020, 12:40 PM | #9 |
07-08-2020, 10:45 AM | #10 | |
Drives: chevrolet camaro Join Date: Mar 2020
