07-09-2021, 06:54 PM | #1 |
Drives: 2012 RS/SS Join Date: Jun 2021
What piece Am I missing on back of engine for cover?
So I got an engine cover from a friend and put it on since my 2012 LS3 didn’t come with one. When I put it on the back clips aren’t attached to anything. Wondering what they are suppose to attach to that I’m missing. Pics included.
07-09-2021, 09:27 PM | #2 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
This is what that needs to clip onto. It mounts at the rear of the engine.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
07-09-2021, 10:40 PM | #3 |
Assuming whoever had the car before you didn't run the cover and took that off since it's kinda ugly without a cover on. I took mine off also as I don't run a cover.
07-10-2021, 01:08 AM | #4 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I took my cover off too and threw it in the trash 🗑
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
07-10-2021, 02:37 PM | #5 |
Throw it in the trash!! Tossed mine long ago. Keeps the heat in too much. Also that piece that is missing, if you purchase it to use the cover, just a heads up you will have th remove the 2 "rear most" intake manifold bolts to install it, and it is a pain because they are so long. Good luck.
