09-02-2020, 03:48 PM | #1 |
Drives: Chevy Camaro Join Date: Apr 2019
LS3 Head Recommendations
I am planning a LS3 build and I had a set of heads I was looking into but now I am not so sure. I was looking a t the Chevy Performance CNC heads but now I am not so sure. I started thinking maybe I should just pickup a pair of stock heads and have them ported and milled but then I thought maybe I should just go big and get a set of something from a company like Frankenstein. I am am keeping it stock cubes and looking to be around 500-550 crank HP. Not married to the number just something i am shooting for. No boost at least not for the foreseeable future. I just am looking for the best heads for my application with the possibility to grow. Any help would be appreciated. Thank you.
09-02-2020, 08:45 PM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Look at GPI or Texas Speed they have nice products, Katech as a good program for stock heads as well, Frankenstein are nice but ouch the price tag.
Orange Krush II
09-03-2020, 01:52 AM | #3 |
Grumpy Grey-haired Guy
Drives: Camaro, Corvette & Merc C300(daily) Join Date: Aug 2014
GMPP do a kit of CNC heads and their "hot cam" - they claim 50 hp increase; coupled with some long tubes and a decent intake system this should get you somewhere near where you want to be and she'll still be very streetable.
09-03-2020, 05:53 AM | #4 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
I went with a set of Frankenstein heads and am very pleased. Prior to that I had my factory heads ported.
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
09-03-2020, 06:47 AM | #5 |
Drives: 2015 2SS Stock Join Date: Sep 2018
Wilkies performance. Smaller shop great prices and reviews. Also watch Richard Holdner on youtube. Prolly the best source of back to back same motor same day Dyno test out there. He taught me a lot on What stock heads will do.
2015 2SS auto. AGP twin turbo, LS9 cam, BTR 660 springs, LS9 Gaskets, ARP studs, 400lph UPP fuel system, MBRP XP 3” cat back, 305/30 Micky Thompson Sport comp tires. 12” Fockford fosgate P1, Rockford Fosgate 600w amp.
09-03-2020, 01:40 PM | #6 |
I already have the Cam. Its the Cam Motion Titan 3
09-03-2020, 02:07 PM | #7 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Soooooooo Frankenstein heads enjoy pepperoni pizza too? I must say you treat them well
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
09-03-2020, 03:09 PM | #8 | |
As for head recommendations, it really depends on what your budget is. If you need a budget head there is GPI, Katech, or TSP for porting services using your existing heads. Or you can go all out and buy the best and have LS heads for life such as Frankenstein, Mast Black Label, AFR, Dart, WCCH, Trick Flow & World. Somewhere in the middle of the road is TEA, PRC, GMPP, etc. Obviously that is a lot of quality heads to choose from, which is where it pays to start searching for some of the Head Shootout videos. I think Richard Holdener has a square port LS head comparison and you can also find some at nearly all of the big online engine magazines, such as Hotrod.com.
09-04-2020, 08:14 AM | #9 | |
09-06-2020, 12:42 PM | #10 | |
Drives: 2014 Chevy SS Join Date: Nov 2014
For a NA LS3, any decent ported or aftermarket head with a 260cc intake port is enough. I have AFR Mongoose heads on my stroked LS3 and Texas Speed PRC heads on my H/C LS3. Best of luck! KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4 2014 Chevy SS --- 429ci Hydraulic Roller LS3 |
09-07-2020, 11:09 AM | #11 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
For power increase from what I have seen, and told by a top shop, heads will be in 10-15 rwhp range, more with bigger cam. So see if $$ of heads are worth it. I say that to as your crank ho range is what my car does, and I have a stage one cam, tune, Cai, shortys and catback with cold air scoop. Not a big barn burner for sure.
Thread Tools | |
