03-22-2023, 04:04 PM | #1 |
Drives: 2013 Chevrolet Camaro 2SS M6 Join Date: Dec 2020
Replacing e brake handle
Hello fellow Camaro owners ! I replaced my broken e brake handle in my 2013 SS and I have a question about removing the heat shield under the car to hook the cables back to it . I looked under the car and the shield has some weird looking fasteners holding it on . What do I used to get them off without destroying them or do you need to and then buy new ones ? TIA !!!
2013 2SS LS3 M6 ... CAI , ported throttle body, comp 54-444-11 cam , Brian Tooley springs retainers and locks , CHE Trunnion kit, C5R timing Cain and gears with LS 2 tensioner block , Texas Speed 1-7/8 headers , comp 7.4 hi tech pushrods, Vitessee throttle controller , SCT Tuner with tunes by Dyno Steve
03-22-2023, 06:44 PM | #2 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
They are just little nuts that will unscrew. They also have these which will do the same thing.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
