07-01-2023, 07:07 AM | #1 | |
Drives: '94 Z28+ '15 Z/28 Join Date: Jun 2009
CAM and new Aero rules
How many of you guys run CAM in here?
I added a wing this year and have some data on what the optimal angle should be for maximum downforce (drag be damned). I took a ton of flak for my setup, but the car feels fantastic. In the next few weeks, I'll adjust my meter and try to get the most accurate readings possible. Most wing manufacturers test them out to 10 degrees AoA, and say that they stall beyond that angle, and to add a second element. I did some single element testing with a smallish wing (4.5sq/ft) and found that it was making more downforce well beyond what the experts say is the "stall" angle.
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C 1980 Z28- resto-mod project 1979 Y84 Trans Am 1986 IROC-Z |
07-01-2023, 08:35 PM | #2 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
Do you have a link to the new rules? I haven't seen them and didn't find anything with a quick Google search.
07-02-2023, 08:10 AM | #3 |
https://www.scca.com/downloads/59661...rules/download
Basically the rear wing can't go too far above the roof line or back beyond the rear bumper. It can't be wider than the car, and total surface area of it can't exceed 8 sq/ft.
07-02-2023, 01:18 PM | #4 |
Drives: Chevrolet Camaro, Ford Mustang Join Date: Oct 2019
Nice work... any close ups of the wing setup? yeah, you can run something like 10" above Roof line... and 6" max rear of the bumper.
You can also add a front splitter that goes 6" forward max of the front fascia. I run the 9 lives dual element rear wing, and an MFR front splitter. Best regards, Dave
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, MFR Engineering, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair |
07-02-2023, 04:18 PM | #5 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
I run in CAMC, and imo SCCA totally f'ed folks who built according to last years' rules and the .819 PAX index, considering CAM cars have to be street legal as well. Most people who drive their cars on the street don't want huge wings and splitters on their cars.
Not a lot of people who have Camaro race cars with full aero participate in autox, but TONS of people who have Mustang and Camaro street cars with a few handling mods and alignment mods or even power mods that throw them out of FS run CAM. Also, PAX is supposed to be determined by actual results and not a theoretical build nobody has actually run. So thanks for the info on wings, but SCCA sucks for doing this. Last year's .819 PAX was a little soft, but the .827 PAX is ridiculous for a full-weight car with minimal mods. Now I have to raw-time C6Zs and Cayman GTS's in AS in my 3700-lb Camaro? My previously competitive car is no longer even close. SCCA has their heads way far up their asses on this one.
07-02-2023, 08:11 PM | #6 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
In general, the experts are right: there's an angle of attack beyond which a wing stalls and makes a lot more drag and loses lift. Every wing and installation is different in what that angle is, of course. It's easy enough to determine if a wing is stalling: just install a bunch of yarn tufts on the underside and see if they are "luffing" or not.
I have yet to see anyone even come close to an optimal wing in CAM so far. However, that doesn't really matter because with the current rule set one can easily make more rear downforce than can be balanced out with the allowed front splitter and dive planes. In fact, I would consider moving the rear wing as far forward as the rules allow to try to distribute as much downforce forward as possible. It would look goofy as hell, but that's a function of the current rule set. I agree that CAM should not allow wings, but that ship has already sailed.
Matt Miller
2020 SS 1LE |
07-03-2023, 06:45 AM | #7 | ||
https://www.youtube.com/shorts/EL_arifKuS4 This was with a single element that is way undersized for CAM. It's roughly 4.xx sq/ft. I have a new testing setup that won't deflect any of the downforce and "should" give me more accurate readings. Hopefully I'll get some data this weekend.
07-03-2023, 09:19 AM | #8 | ||
This is kind of a detour from the thread topic, but the real issue with CAM and pax is that nobody - and I mean nobody - is running a car that's even close to maximizing the full CAM rule set. If you started your CAM build with a production car platform, you already gave up huge opportunities. CAM actually allows a bespoke tube-frame chassis and any suspension one wishes, as long as it retains stock wheelbase for the car it's trying to emulate. You can also put a full carbon fiber body on it, set the engine anywhere in front of the driver, etc. Think along the lines of Mike Dusold's "Camaro." All you have to do is trick your state into licensing it and (maybe) inspecting it. A proper CAM building should require about 500lb of ballast to make minimum weight, it should have a very low CG, and it should have a weight bias of about 40/60. It should not be remotely streetable, even though it must technically be legal to drive on the street. Anything less than that is not a full CAM build. This is why I got the hell out of CAM: the rules are just plain ridiculous. CAM-S is even worse: you are explicitly allowed to run a kit car replica of a British roadster with a 90" wheelbase and any engine you want at 2500lbs (which done properly still requires ballast), but a 84+ Corvette has to run at 2900lbs because they are believed to have magical powers. why nobody has emulated Kiesel's Sprite but on a 90" wheelbase with an AC Cobra body is beyond me, but you get the idea of how fast and unstreetable a proper CAM-S build should really be. CAM sort of implies that it's about modified production cars that still get driven on the street, but it very much isn't. It is not a class for "hotrodders," and yet those are the only people interested in running in it. The current state of CAM is a hot mess.
Matt Miller
2020 SS 1LE |
07-03-2023, 10:53 AM | #9 | |
The issue with current rules is there's no ST class that our cars fit into, STU is full of much smaller cars more suitable for autox and a .830 PAX. So anyone with mods past FS is in CAM by default, there's nowhere else to go. CAM-T should theoretically be slightly faster than CAM-C with it's smaller cars and lighter minimum weights. We have 2 Fox body Mustangs with IRS conversions running 315s at ~3000 lbs... It's really not a huge deal as far as results as nobody is paying me, but it's frustrating to prep a car for one set of rules with a .819 PAX only to have the rules and PAX change so drastically. If I would have known I'd probably have remained in the street classes and have that nice, soft .813 FS PAX, lol.
07-03-2023, 06:33 PM | #10 |
My point with regards to the PAX was that a CAMC car with a spoiler and .819 is likely more competitive than a CAMC car with a wing and .827 PAX. On a standard 35 second course the SCCA is saying that a wing is worth .339 seconds. I'm not buying it. I'm fairly certain that from 0-40mph a spoiler is producing more downforce than a typical dual element wing setup. We spend most of our time floating around the 25-50mph zone at an autocross. My force gauge was binding up because of the way I had it mounted. I changed the entire mounting setup so it can "float" as the lid gets pushed down. It will be far more accurate for my next round of testing.
This is some interesting data for those that say steep angles don't work. Check out the downforce at 52 degrees at 80mph:
07-03-2023, 10:29 PM | #11 | |||
The bottom line on the CAM-C index is that a car built to max out the rule set is a bespoke race car and should be faster than any street class, whereas right now the index is between AS and SS. The fact that nobody has built a true "max effort" CAM-C car so far is the reason it seems too hard of an index. As DaveC113 implied, what most people in CAM-C really wanted to make is a car modded to ST levels. Unfortunately, instead of making a useful ST class for modern pony cars, SCCA has a non-jacketed class that caters to Optima builds and allows nearly anything, including full frame and body changes. That sucks, but the problem is the class structure rather than the index. Quote:
Matt Miller
2020 SS 1LE |
07-04-2023, 06:32 AM | #12 |
The only max effort CAMC car that I know of would be that GM test vehicle from few years ago. I only say this because it was able to hit the minimum weight target. That's really the hardest thing to do with CAMC cars. It was that turbo-4 1LE. They got it making really good power, and the F/R balance was excellent. This was before the wing rules. There is one that ran at Bristol as well by John Ward. He had everyone covered by 1.168 seconds on Sat and by .738 on Sun. he was 14th in PAX on Sat, haven't seen the numbers for Sun.
07-04-2023, 08:24 AM | #13 | |
A true edge-of-the-rules CAM build looks like a Sprint Cup car (CAM-C) or a slightly larger version of Kiesel's EM Sprint (CAM-S), but with more wing and on 200tw tires. If you can drive it to the event, fuggedabowdit. The only thing OE on it should be the VIN plate, which is welded to the custom tube frame, and maybe the wiper motors and mirrors so you can pass a state safety inspection.
Matt Miller
2020 SS 1LE |
07-04-2023, 11:15 AM | #14 |
Minimum weight for CAMC is 3480 with driver. I don't see how a tube chassis will be a help if you can get the car way under that mark with a stock turbo-4 chassis, and then add weight where you want to. Modern chassis' are extremely stiff. The tube chassis would be significantly lighter but if there's a minimum weight to meet and you have to add several hundred pounds then it may be a moot point. That GM car had way more secrets in it, then they let everyone believe. I have 2 friends of mine that were "in the know" regarding the 3 or 4 cars that they had campaigned during that time. They basically had an unlimited budget and were green lit to try anything and everything that they could think of, and a few things made it into the production cars, specifically the eLSD tune that they developed.
When I get my car back out for some more testing I will try smaller increments of wing angle to see what happens. I'm currently waiting on a longer cable for the display. It's a royal pain in the ass to record a video while the display is just out of sight in the back seat area lol. It comes with a 6 foot cable, i'm having them build me a 12 foot cable.
