Old 11-22-2013, 07:20 AM   #1
Bo White
Bo White's Avatar
LS3 lifter tick
Well, mine has developed a tick on the driver side. With Christmas weeks away I don't have the coin I'm willing to let go to do a cam swap since a bunch of other things need to be replaced/upgraded during that process. I'm going to only do what the bare minimum is to remedy this issue. See if I've got the list right:
New lifters(duh)
New push rods(upgrade)
Trunion kit(upgrade)
LS9 head gaskets(since I'm under boost)
ARP head bolts(upgrade)
Coolant
I'd love to throw some springs on and a cam but then I'd do other things along with that and don't REALLY need to do that right now.
Why couldn't this happen in April/May lol?
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 11-22-2013, 12:01 PM   #2
Piccione Performance
Piccione Performance's Avatar
Drives: 2010 2ss/rs & 2014 Stingray
If your car is still stock you should still be under your 5/100 powertrain warranty.
Piccione Performance is offline   Reply With Quote
Old 11-22-2013, 12:08 PM   #3
Bo White
Bo White's Avatar
According to two dealerships not with the Paxton hanging off the front of it.
Totalled:
Old 11-22-2013, 01:26 PM   #4
Are all the internals stock? Just the S/C? If so, check with a few other dealers. I work with 2 locally when my clients have warranty issues to make it easy on them. We have had no problems when lifters or stock valve springs have failed, they take care of it as long as the mods don't cause the failure. Go talk to the service manager.
If you replace the lifters, you need to pull the heads so may as well do it all at once.
Old 11-22-2013, 01:38 PM   #5
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Man, if you are already changing all of that, a cam and springs arent all that much more money.
You should really just find a way to make it work, or live with the tick for a little while, or if you have another car you might be able to drive in the meantime.
You really are going to hate yourself for giving up an opportunity to throw a cam in there when you already have done 80% of the work.
If you end up doing the cam, oil pump and timing chain are worthwhile upgrades.
I understand if you cant make the cam work.
But you will also need a spring compressor tool when you take the rockers off to do the trunnion upgrade and replace the rods/lifters.
You should also get a torque wrench to torque everything back down afterwards.
Old 11-22-2013, 01:57 PM   #6
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
I don't suppose you have a video of the ticking? Mine is pretty clicky too, but I don't think there's anything wrong with it. I'm pretty sure you know the difference between OK and not OK, but I wouldn't mind hearing it just for my own knowledge.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 11-22-2013, 02:26 PM   #7
Bo White
Bo White's Avatar
Well, I've got tools lol so that's not a problem. I've got spring compressors, I've been porting cylinder heads for about 15 years.
Totalled:
Old 11-22-2013, 02:55 PM   #8
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Haha
Old 01-29-2014, 08:15 AM   #9
Bo White
Bo White's Avatar
Update.
I was going to give it enough time to be sure not to be premature on the outcome. It was time to change my oil and read were a lot of people were running anywhere from 1/2 to 1 quart low on oil to remedy lifter tick. The theory behind it is there is so much oil in the pan that the crank paddles the oil just enough to airate the oil and the air accumulates in the lifters and makes them tick. I figured since I was changing oil anyway I figured it was a free try lol. I prefilled the filter as always and put 7 quarts in the pan( a little over 1/2 quart low) and have been running it like that for 5000 miles. The lifter hasn't made a peep since. Is there something to it? Yes. Is the theory true? Not sure but it sounds reasonable.
Hope this helps others as it has seemed to help me.
Totalled:
Old 01-29-2014, 08:34 AM   #10
thahemp
Geek
thahemp's Avatar
Update.
I started running a 1/2 qt. low right after I put the headers on and noticed how noisy the lifters were. It had the same effect in my situation too FWIW. Seems to do the trick.
x = ~x
Old 01-29-2014, 10:33 AM   #11
trw427ss
trw427ss's Avatar
Drives: 2013 2SS/RS L99
Mine had a tick to so I did my first oil change at 800 miles and have been running it 1 quart low every sense and with 8000 miles no tick! Now I just did my VVT cam install and put in Morel lifters.
2013 2SS/RS L99/A6 Crystal Red Metallic Tincoat 12.76@108.98mph Bone Stock
12.46@111.19mph with New Era CAI & U/D Pulley
12.12 @ 114.16 after Stainless Power headers and no tune yet on stock P-Zero's!
12.007@ 115.20 With 18" Drag Radials - 11.93 @115.19 Added a PTB 11.76 @116.59 With Yank SS3200 Converter - 11.63 @116.52 After PI and Tuning 11.44 @118.75 New Best
10.72 @127.93 after heads and Cam and Yank SS3600
trw427ss is offline   Reply With Quote
Old 01-29-2014, 02:28 PM   #12
Madness11
086YN
Drives: Black 2SS/RS Demon of Madness
I may have to try this. I just cammed my car, and between my exhaust being loud and my stereo up so loud, I stopped paying attention to the tick when the stock cam was in. After I put the cam in, I about crapped my pants thinking the rockers were getting loose. So I went back and re torqued the rockers and everything is fine. but it was a scare for sure. I will have to try to remember to short my oil change by a quart next oil change. Saves money anyway.
Madness11 is offline   Reply With Quote
Old 01-29-2014, 08:30 PM   #13
SolomonAKOO
SolomonAKOO's Avatar
Drives: 2011 2SS/RS
Update.
Wow great info there! I'll have to try this out. I'll be doing an oil change in the near future too.
1 7/8" TSP headers straight piped, Custom Tick Performance cam w/ supporting mods, 1" BMR springs and other BMR suspension mods. Tuned with HPtuners by Matt@FSP
SolomonAKOO is offline   Reply With Quote
Old 01-29-2014, 09:33 PM   #14
thahemp
Geek
thahemp's Avatar
Do it like Bo said though. Buy 8 quarts, use 7 and just fill the filter with the 8th and leave the rest out. It works and the more oil you can get away with, the more heat you can pull out of the engine.
x = ~x
