Old 04-07-2015, 11:34 PM   #1
95RedCamaroz28
Drives: 2010 Camaro 2SS/RS M6 Rally Yellow
Oil Cooler Delete Question
I recently bought an aftermarket oil cooler but the lines will not clear the factory oil cooler. Is there anyone who can walk me through how to remove the factory oil cooler and cap off what needs to be capped off. Cannot seem to find any DIY threads on this.
95RedCamaroz28 is offline   Reply With Quote
Old 04-08-2015, 03:31 PM   #2
J-Crazy Camaro
J-Crazy Camaro's Avatar
Drives: Red V8
are you saying you are trying to run 2 oil coolers?
Live Hard, Drive Fast, Die Free. 'Merica
J-Crazy Camaro is offline   Reply With Quote
Old 04-08-2015, 03:57 PM   #3
Ragnar
Destroyed by flooding
Ragnar's Avatar
Drives: Wife's car
^^^ having issues with existing oil cooler?
Old 04-08-2015, 04:13 PM   #4
LOBBS
LOBBS's Avatar
There's a thread around here explaining why the factory oil cooler is ineffective I just can't remember where I've seen it. The guy was setting up his L99 Camaro for road-racing and got into quite a bit detail on aftermarket trans and oil coolers. Basically, because the factory oil cooler is cooled with engine coolant you can never really bring the oil temp down below the temp of the antifreeze. It's a better option to get a separate cooler for each so that you can directly use airflow.
LOBBS is offline   Reply With Quote
Old 04-08-2015, 04:20 PM   #5
Ragnar
Ragnar's Avatar
Drives: Wife's car
I understand that the track guys will pretty much always upgrade something from OEM. My DD has no issues, and no plans for tracking at this time, OEM is great. Need some more info on why the upgrade from the 0P!
Old 04-08-2015, 08:11 PM   #6
95RedCamaroz28
im going to install an aftermarket oil cooler. But I cannot fit the hose lines without removing the factory cooler
Old 04-08-2015, 08:29 PM   #7
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
According to my oil temp gauge, assuming it's remotely accurate, I was hitting maybe 260-270 at VIR this past weekend for a 25 minute session. That seemed more than comfortable enough. Of course the ambient temp was around 65*F.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 04-08-2015, 10:01 PM   #8
FASTDIESEL
FASTDIESEL's Avatar
Drives: 2010 2SS/RS L99 SLP Cosmetics
BoWhite deleted his. It's documented in one of his threads.
I've seen where the stock fitting in the block is difficult (impossible) to remove without the aluminum threads coming out with the fitting. That would be a MAJOR show stopper, in the middle of an "easy" mod. Look before you leap!
13.244 @ 104.91 100% stock (#17).
Now - Mike Norris catch can. 245/50/19 Firestone Wingfoot A/S on LT2 black powder coated rims (square). 1 7/8" Speed-Engineering LTH, off road pipes, tune.
Now 12.93 @ 109.13.
FASTDIESEL is offline   Reply With Quote
