12-03-2018, 08:08 PM | #1 |
Drives: 2010 Camaro Join Date: Nov 2018
Help me decide on build...
I am thinking of purchasing a Livernois 419 or a TSP resleeved LS3 454. Which would you do for the money? This is not a race car. Just a street beast.
12-03-2018, 09:10 PM | #2 |
Drives: 2015 1LE Join Date: Oct 2015
I think I would go with a 427
12-04-2018, 02:50 PM | #3 |
Is there a reason behind this? Or just personal preference? I talked to Livernois about the 419 with a 2c camshaft. I think he is giving me a good deal. Might get the PRC heads? Would this make a good street combo? I was thinking maybe the 3c, but don't want to move my torque curve to high in the RPM. Thoughts?
12-05-2018, 02:42 AM | #4 |
Drives: 13' 1LE Join Date: Apr 2012
224 236 seems ultra small for 419ci+ build. I'd def look at a bigger one. PRC are good for the money but again what kind of PRC heads? Ls7 ,LS7 custom?
I would go with LS7 heads and ported MSD at the minimum with custom cam for it. It would beat your 2c idea by at least 100hp imo(just throwing out numbers but it could be more lol). Cnc LS3 heads and a custom intake would work too. LS3 intake will become a big restriction with your stroker.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
12-05-2018, 04:17 AM | #5 |
Yeah Id run atleast 235* intake sized cam.
12-05-2018, 09:00 AM | #6 |
The TSP 427 uses a brand new 7.0 block! No resleeves or funky crap. The 7.0 makes great power if paired with awesome heads and the right cam.
What are you trying to do with the car? Keeping in NA? What is your budget? Stay away from Livernois, stick with TSP. |
12-05-2018, 10:23 AM | #7 | |
Drives: 2010 Camaro 454 LSX (SOLD) Join Date: Jun 2013
12-05-2018, 10:36 AM | #8 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
ZZ just curious as to why you say stay away from Livernois. I’ve never heard anything bad about them, but then again I don’t hear everything mentioned. Thoughts
12-05-2018, 10:57 AM | #9 |
Many people don't know this, but we stay away from the LS7 block and stock sleeves because it's actually the weakest block/sleeve in the entire Gen4 engine family. Just research LS7's with cracked sleeves, it's very commonplace. A sleeved 5.3/6.0/6.2 is superior in almost every way beyond bragging rights.
12-05-2018, 11:53 AM | #10 | |
12-05-2018, 11:59 AM | #11 |
Jake, I actually talked to Dave yesterday. But I forgot to ask as many questions as needed. He did send me a quote for an assembled short block with cam and chain installed. But, I forgot to mention keeping VVT among other things. To keep costs down, at least for now, I am thinking of sticking with my heads and having them reworked. Same with the intake manifold. I think I will send that off for rod mod/porting. Thanks
12-05-2018, 12:03 PM | #12 |
Staying NA. This will just be a street beast. I don't track it. I just don't want to put it back together and a month later regret something.
12-05-2018, 12:11 PM | #13 | |
Engineer
Drives: 2014 Camaro 2SS RS 1LE Join Date: Jun 2015
Katech 416 is what i'd go.
2014 Red Hot Camaro 2SS RS 1LE
-Sunroof Delete, Recaro, Nav, NPP -Pegasus Subframe Bushings, JPSS Radius Insert, Detroit Speed Caster Mod, PMAS Intake, Solo High Flow Cats, Ecsta PS91 Tires, MGW Shifter, Pegasus Offset Poly Diff Bushing |
12-05-2018, 12:23 PM | #14 | |
