07-05-2018, 07:58 PM | #1 |
Drives: 2015 2ss/1le Join Date: Oct 2013
Vin Number Production
Ok I have been researching and I think I am a little confused. Do the last few digits of my vin symbolize the production number of that model year. My last few digits for my 2015 are F9100039 so does that mean I have the 39th Camaro built for the 2015 model year?
07-05-2018, 08:30 PM | #2 | |
07-05-2018, 08:47 PM | #3 |
07-05-2018, 08:57 PM | #4 |
07-05-2018, 09:02 PM | #5 |
07-05-2018, 09:17 PM | #6 |
Drives: Miss Con Ception Join Date: Aug 2016
If you have a 1LE there is no need to brag.
2011 1SS/RS LS3 CGM
07-06-2018, 05:59 AM | #7 |
Started#gottalovethatblue
The problem with using the VIN for build order is that after the ZL1 and Z/28 Camaros came out the order got all screwed up. They had special sequencing that was outside of the normal final 6 numbers of the VIN. OP, you definitely have a low build number, but it may be a little higher than 39 if there were any ZL1 or Z/28 cars built before yours.
07-06-2018, 08:55 AM | #8 |
If you open the drivers side door there are labels there that will have your build date , also under the hood find the fuse box and look down lower on the cradle of the car and there will be a label with date and time .
07-06-2018, 11:26 AM | #9 |
Space Shuttle Aficionado
Is this for all 5th gens?
07-06-2018, 11:35 AM | #10 | |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
07-06-2018, 11:48 AM | #11 |
07-06-2018, 12:54 PM | #12 | |
Only the 2010s had sequential numbers, IIRC. After that all the 5th gens were mixed with the other cars coming down the line. The sticker on the frame rail was applied when the front sub-frame was produced, not when the car was completed. Z/28s were sub-contacted out and have unique serial numbers.
2011 1SS/RS LS3 CGM
07-06-2018, 01:22 PM | #13 | |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
It can be days after that date.
Thread Tools | |
