07-15-2018, 06:41 AM | #1 |
Drives: 2002 Camaro SS Join Date: Jun 2012
Secondary cat delete pipes?
Anyone make a bolt in secondary cat delete pipe that works with the stock exhaust? Not wanting to weld in anything if possible. Not sure if the stock ones are welded in though. I know borla has some, but guessing it's only for Borla exhaust.
2017 1SS Hyper Blue M6
2001 Ford Lightning |
07-15-2018, 07:37 AM | #2 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
No one makes a true bolt in design, as the factory exhaust is one piece (including the secondary cats). The closest thing is the Borla 60606 mid-pipe, which can be installed with clamps and no welding is required.
07-15-2018, 08:54 AM | #3 |
Ok, but will the Borla 60606 work with the stock exhaust? The description reads like it works with the 3 inch Borla, will it clamp to the factory 2.75 piping?
07-15-2018, 09:18 AM | #4 |
The Borla 60606 is 2.75" and it will work with the factory exhaust. I think there's at least a dozen threads covering this, and even has links for the clamps that you need.
07-15-2018, 05:11 PM | #5 |
Drives: 2017 1SS 1LE Silver Ice Metallic Join Date: Jun 2016
I picked up a Borla 60663 but have yet to install it. https://www.borla.com/products/camar...rt__60663.html
I got it from RDP for a really good deal. |
07-15-2018, 06:30 PM | #6 | |
Daily Driven 1LE
Drives: 2018 1SS 1LE Join Date: May 2018
I paid a shop $100 to delete my secondary cats. With or without that kit you're still cutting the factory exhaust. Why spend $200+ extra AND have to do all the labor. Go to an exhaust shop and play stupid. "Yes, I'd like my resonators after the cats deleted."
2018 1SS 1LE
07-16-2018, 01:00 AM | #7 |
Because it's a bolt in affair. You could easily swap them back in if you wanted/needed to.
07-16-2018, 08:38 AM | #8 | |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Also most shops are not dumb enough to believe the "resonator" line, they all know that modern new cars after 2009 have 4 cats on them now. |
07-16-2018, 08:45 AM | #9 | |
07-16-2018, 05:15 PM | #10 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Yes (Hans)solo, the 60606 works great when you cut the stock pipes 8" out from the your stock muffler (NPP?). Then you can always bolt the stock cats back in anytime using the same sleeve clamps. The 60606 is the same 2.75" through out as stock.
Look here- https://www.camaro6.com/forums/showthread.php?t=492077 Skip to about page 8, that's when we got his issue sorted. Note at post #104, Dave Borla promises to make a less expensive version of the 60606 and has made good on that with part #60663. Post #103 is correct about this clamp- https://www.summitracing.com/parts/vpe-1176 making it weld free with the 60606 and I believe the last post in this thread is correct that the full 60606 will be louder that just the cat delete 60663. But the '63' is half the cost. Have fun! Last edited by Ventmaster; 07-16-2018 at 05:39 PM. |
07-17-2018, 12:20 AM | #11 |
Drives: 2018 1SS 1LE Join Date: Aug 2017
You have to ask yourself, am I really ever going to put the secondary cats back on? If the answer is no you can run either system. No matter which one you pick, you will need to cut the factory exhaust to make it work. If you weld in the new pipes you will have to cut it again if you want to put the cats back on. Why GM decided that these 1 piece systems are a good idea makes no sense.
07-17-2018, 08:20 AM | #12 | |
07-17-2018, 11:04 AM | #13 | |
07-19-2018, 12:47 PM | #14 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
What does an X-pipe give you other than a little extra sound?
If say I plan on doing a Corsa Exhaust, what would be the added benefit to also get an x-pipe at the same time, as opposed to just the Corsa by itself?
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
