07-19-2018, 10:48 PM | #1 |
Drives: 2011 camaro 2SS M6 Join Date: Nov 2014
5 inch intakes
Does anyone sale 5inch intakes compatible with the slp supercharger?
07-20-2018, 11:32 AM | #2 |
Drives: 96SS Join Date: May 2009
Our intake will more than likely fit.
07-20-2018, 12:11 PM | #3 |
'It's an experiment'
I have Frans 5" on my LSA..
Great setup: https://www.camaro5.com/forums/showp...postcount=2070 MAF tuning takes a bit of work but, it’s worth it. Give your tuner a heads up... -Don
747 RWHP 794 RWTQ
07-20-2018, 01:53 PM | #4 |
Drives: 2011 convertible 2ss/rs Join Date: Sep 2015
And why would a 5'' takes more to tune
Sent from my SM-N950U using Tapatalk |
07-20-2018, 02:39 PM | #5 | |
Boosted Moderator
It could be due to the larger size of the intake.... Moving relatively the same volume of air through a larger body will affect the air flow sensor readings. The specific volume of air will be flowing slower. in a larger chamber and faster in a smaller chamber... A good tuner will be able to maximize the potential for a given device... if possible...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
07-20-2018, 02:58 PM | #6 |
Thxs for the info
07-20-2018, 03:37 PM | #7 | |
Here is all we changed (Mostly Mark): https://www.camaro5.com/forums/showp...postcount=2115 I also run E85 -Don
747 RWHP 794 RWTQ
07-21-2018, 05:49 PM | #8 |
Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
What's the gains going to 5"?
