02-05-2022, 01:14 PM | #1 |
Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
Upgraded the zl1 pump in bucket
In the past I upgraded to the ZL1 pump. When I went to E85 I quickly ran out of pump. I decided to add a bap and outran that too. So then I added an auxiliary pump. At this point I decided that I wanted better than the ZL1 pump, but didn't want to lose any functionality of the oem system and I didn't want to spend a bunch of money on some of the name brand systems.
So... I decided to swap out the pump in the bucket and keep all of the oem systems in working order while converting to a return style system. With my new in tank pump I still have saddle side pick up and the fpcm still reads total fuel pressure. The pump is 340lph compaired to the ZL1 @ 250lph and is pwm. Picture 1 shows how I added x3 umbrella valves to go with the oem black one on the bottom of the bucket. You can also see that the venturi is connected and the return flow pipe has been modified a little. Picture 2 shows how I removed the oem filter from the base but left all of the legs. 1 leg hold part of the sock and 2 others are in place for the spring rods. Picture 3 shows how I shaved all of the stuff on the top of the black core except for the 1 hose hook. It also shows how I opened up clearance holes for the return line and to allow the feed line to relax into when the housing is compressed during installation. Picture 4 shows all of the lines and electrical in the relaxed position. Picture 5 shows the new feed fitting. The old feed fitting is now the return that flows back into the bucket. Picture 6 shows the complete unit ready for installation. (At the correct 6.5" compressed height) The oem pressure regulator is in place only to block the hole and serves no other function. (1:1 rising regulator does the job now) Picture 7 shows the complete plumbing of the fuel system
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
02-05-2022, 07:57 PM | #2 |
Drives: 2010 2SS/RS Join Date: Feb 2020
From your signature you don't seem to have spared any expense. So my question becomes why don't you check DSX Tuning for all your E85 parts?
02-06-2022, 09:57 AM | #3 | |
I am a little old school and like to do all of the work myself that i can. I love to tinker and figure out how to do stuff in my garage. I also built almost every part of my signature myself. Of coarse I bought parts but did not buy any kits. It's time vs money It took time for me to research and figure out how to do a lot of the stuff that I have done vs just paying to have it built or done. I enjoy the process an am willing to share how I do things. I found no guides or references to do this bucket this way so I figured it out myself and made this post. This project was very cost effective for the gains in flow and I could do this setup for a returnless style too. I am making one for a local buddy that wants to go E85, so I am also setting him up with the way I did all of mine. To me this is what this community is for, share and learn.
02-06-2022, 10:33 AM | #4 |
Drives: 2011 Camaro SS Join Date: Jul 2017
Very cool work!
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
02-06-2022, 11:35 AM | #5 | |
02-06-2022, 04:58 PM | #6 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
Very well done!!!
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
02-06-2022, 07:05 PM | #7 | |
Not questioning your abilities mate, when I don't know the answer I have to ask a question. Nice work |
02-06-2022, 08:09 PM | #8 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Why not run a Y after the filter and feed each rail in parallel? That way you can put the crossover on the outlet and tie both FPR ports together?
02-07-2022, 07:00 AM | #9 | |
The way I have it set up should give all cylinders equal pressure with the regulator holding pressure at the end of the system.
02-07-2022, 07:52 AM | #10 | |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Thanks for the writeup. I may end up doing this.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
02-07-2022, 08:16 AM | #11 |
A lot of interesting things are borne out of necessity.
I like it when I explain these things to my wife and ask her.."does that make sense?" And she replies with "does it make sense to you?" Wich of coarse I reply "yup" as she goes back to her game that I interrupted. (Good times)
02-07-2022, 03:05 PM | #12 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
https://aeromotiveinc.com/wp-content...0109-0revH.pdf
The way Joshnmn suggested is optimal. You claim you kept all the OEM features... You haven't kept the ability to control fuel pressure VIA FSCM, and you will likely max this out also. I don't see the problem on spending money in this area. The dual/triple options on the market give you steady, repeatable fuel pressure that makes tuning easy. You can run a stock FP sensor on any system and some aftermarket options do have the saddle pickup. I think its a bit complicated. You could sell all of those parts and buy an AGP dual pump kit for $1500. You already have everything else you need. It's not a terribly huge investment for a safe fuel system. Have you tried tuning it yet? Sorry if I sound negative, but you're reinventing the wheel.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
02-07-2022, 03:27 PM | #13 |
I like to build stuff. (Of coarse I am re-inventing the wheel) imagine if no one tried to take a different path vs the beaten 1.
To me it's not complicated at all, I like to tinker. It's a pwm pump that is controlled by the fpcm just like the factory pump was. My "whole" system was fun to figure out and was cheaper out of pocket then buying a ready made kit. If I outrun this setup I will change it. Tuning it is no different than Tuning your stock system because the pump is pwm just like the oem, and the fuel pressure is read from the total source that includes all of the pressure/flow sources just like the oem. (This is the easy part) I could have did it without having it set up as a return system if I wanted too. But since I also have an aux pump (not a kit) I went return style to eliminate the psi spike when the aux pump kicks in. (That's part of that pesky Tuning part you were worried about) I am not going to go down the rabbit hole with you. If you like it cool, if you don't like it that's cool too. I am just sharing what I built. You mad bro? (Makes me think I shouldn't try to share my silly projects... sheesh)
02-08-2022, 05:32 AM | #14 | |
Your post made a couple false claims, and I was just having a discussion about those claims so future readers don't believe them. Maybe you're mad.
