09-25-2017, 02:57 PM | #1 |
Drives: 2017 2ss camaro Join Date: Aug 2017
Got new tires car pulls to the left when given gas
Please help is it my alignment or the tires or what every time i give it gas it pulls to the left brand new tires
09-25-2017, 04:55 PM | #2 |
Drives: 2019 Shock ZL1 Join Date: Jan 2007
Maybe your shop that did the work can help seeing they put the tires on. Are they directional tires? Asymmetric tires (a specific inside/outside to the tire)? What brand tires? Did the shop do an alignment?
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
09-25-2017, 04:58 PM | #3 |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
Pick one:
Multiple choice:
a) Bad tire. b) Bad air pressure in tire. c) messed up alignment when doing tires. d) all of the above. e) some of the above. |
09-25-2017, 05:08 PM | #4 |
Drives: 2016 1ss Camaro Join Date: May 2016
It could be both.
You'll need to get the tires off, re-mounted & re-balanced. Then you will also need an alignment adjustment.
Andrew Bettridge
Account Manager Extreme Dimensions 1-714-278-8000 EXT 17 andrew.bettridge@extremedimensions.com |
09-25-2017, 05:12 PM | #5 |
Drives: 15 SilveradoLTZ,162SSVert BlazerRS Join Date: Dec 2015
Swap the rear tires side to side, See if it pulls the other way!!! Measure the ROLLOUT of both rear tires.
09-25-2017, 06:48 PM | #6 | |
Drives: 17 SS a8 Join Date: Feb 2010
The rollout was 1.5" different on identically labeled tires. The scary part was when I let off the gas at 100+mph and it went back to normal but I was correcting.
dropped a valve in the 6.2. now running a drop in rods and piston 5.3
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
09-25-2017, 09:38 PM | #7 |
It was just the back tires, they're Nittos. At first I drove off and it was pulling to the right really bad, I went back and explained the problem they took off the tires put two more of the same brand and style rebalanced them and now it pulls to the left. Could that be the way they balanced the tires or do you think that the alignment got knocked out of wack while installing? I'm going back tomorrow and demanding a free alignment to help diognose the problem.
Ps. Did not have any problems like this before |
09-25-2017, 09:39 PM | #8 |
I'd demand my $$ and old tires back and go elsewhere.
09-25-2017, 09:40 PM | #9 |
They also scratched both wheels while installing. Icing on the cake
09-26-2017, 03:55 AM | #10 |
376 cubic inches of fun
Are these directional tires and if so, are they mounted to rotate the right way? Look for arrows on the sidewall.
Are the tires asymmetrical, and are they mounted facing the right way? Look for "outside" on the sidewall. Are they both directional and asymmetrical? In that case, each tire is unique and has both rotation and outside marked. |
09-27-2017, 11:50 AM | #11 |
Drives: S O L D Join Date: Aug 2016
OOOhhhhhh........ I'd be beyond pi$$ed at this point........
Club F1FTY
2017 2SS 50th Anniversary Convertible Borla S-Type exhaust NPP| GM CAI | Color matched GM side skirts | Color matched 3rd brake light | Big Worm Graphics smoked out tail lights & rear reflectors | Oracle ghosted side markers | LED License plate bulbs | Door striker covers | Jam handle | Engine emblems from RiverCity Creations | 50th Center Console | Black bow ties | Hawk Performance ceramic brake pads | ZL1 Start button | CQuartz ceramic paint finish | Novistretch bra | S O L D |
09-28-2017, 06:04 AM | #12 |
Chin Event Manager
Drives: 2018 SS 1LE Join Date: Dec 2011
I had a dealer put front wheel on the back. Car pulled under acceleration pretty bad. Knucklehead. Do not assume they did anything right.
09-28-2017, 08:26 AM | #13 |
Drives: 67 goat, 69 goat ram air III Join Date: Mar 2009
OP: this makes sense and could be the/one of the problems.
10-25-2017, 12:38 PM | #14 |
It was the rear alignment after all and a new set of tires to be safe
