View Poll Results: Staggered tires for the stance, or Square for rotation? | |||
Square, like the 1LE! | 21 | 52.50% | |
Staggered, like the ZL1! | 19 | 47.50% | |
Voters: 40. You may not vote on this poll |
Thread Tools |
05-16-2018, 04:21 AM | #1 |
Drives: 2015 2LT Join Date: Nov 2015
Are squared tires worth it just for rotation's sake?
I'm in the process of ordering my next set of tires, and it's going to be the Nitto NT555 G2. I'm torn between 295's on all four corners, or putting 325's in the rear.
I'm aware of the handling benefits of a square setup, though I won't be tracking this car so I doubt that I'll be able to utilize those benefits. My question is, do you think that the ability to rotate front to rear on a square setup is worth it over the look and grip of a staggered?
2015 2LT Cosmetics: ZL1/1LE Wing Spoiler, SS Carbon Hood, Z/28 Carbon Diffuser, SS Front Bumper, RS Taillights, 1LE Carbon Splitter, Phastek U-Halo Headlights, Fade-to-Black Gills
Performance: ZL1 NPP Exhaust, ZL1 6-Piston Brakes, ZL1 10-Spoke Wheels, Nitto NT555 G2 295/35/20 x 4, Magnaflow X-Pipe, Blackvue DR650S2-CH Dash Cam |
05-16-2018, 06:03 AM | #2 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
to me, you answered your own question. You are NOT tracking the car, so why even go square just to rotate. Staggered "looks" better to me, but that again is an opinion, and only your opinion counts when it comes to what you want your car to look like.
If you were tracking your car, heck yes a square setup has many advantages. But you ruled that out. |
05-16-2018, 07:28 AM | #3 |
GPI Sales Consultant
Your signature states you have a set of ZL1 wheels. Those are not square - so even if you square up the tires, you're not going to be able to simply rotate them (Unless you're dismounting the tires every time you rotate).
I have a square setup, and I like being able to rotate. I don't track the car, but I drag-race plenty at the track and in Mexico, and being able to move the rears up front as they wear is definitely a benefit.
Got a question about a GPI product? Feel free to shoot me a message! |
05-16-2018, 11:57 AM | #4 |
Drives: 2018 Charger SRT 392 F8 Green Join Date: Aug 2010
Your going to run 325 on the rears? What size rime are you running for that? I have 11" rears and run 315's.
05-16-2018, 01:53 PM | #5 | |
I'm not sure if rotating the tires is worth trading off the stance, so I'm looking for a consensus.
Essentially, I'm curious of two things: 1. Do wider rear tires provide a notable performance benefit, since I won't be able to rotate them? 2. Is it difficult to remount the tires for a rotation? I was under the impression that this was how tires were rotated in general, but if that's not the case then I am not opposed to forgoing the rotation in favor of wider rears. Quote:
325 is the maximum size for 11", and 295 is the maximum size for 10", no?
05-16-2018, 02:08 PM | #6 |
Got mine!
Drives: 2021 LT1 RS - Orange Crush Join Date: Mar 2011
I've got a square set up so I can rotate, but I also have the same size rims all the way around. Your rear rims are wider thus rotation is NOT an easy operation as the tire would have to be remounted. For me, that alone rules out a square tire set up.
BTW, If you were to go square... disregard the pic below, I've got new 20x10 +35 rims with 285/35/20 and the fit is ideal in my opinion!
Camaro lover since 1984 when I got my first car a 1978 Camaro LT with a 2 barrel carb on 305 V8... yes I put in a 350 with a 4 barrel.
05-16-2018, 02:50 PM | #7 |
With staggered rims rotating tires isn't a quick/easy job, so I'd say that rules it out the rotation angle for you.
However, there are significant benefits to a square setup. In standard staggered form the standard trim LS/LT/SS model cars have a significant amount of understeer balance built into the chassis. This keeps the car nice and safe for the masses, but can be a little disappointing when you start pushing the car in the corners - the front end gives up pretty easy. A square set will bring the chassis balance much closer to neutral, it's a much more satisfying car to push in the turns. For that reason alone I would consider the square setup. The setup you have now should be plenty good for the power level you're at. You could move up to a 315 on the rear, but it would be overkill from a straight line acceleration perspective, and would reintroduce that understeer bias the car has in the chassis.
05-16-2018, 02:52 PM | #8 |
I would say if your running the 11" ZL1 rims then 315's is about the max you would want to go. I think if put a 325 on a 11" rim there would be a huge sidewall bulge and your tires won't wear properly and not look god overall.
I use to run 295's on the stock 9" rear wheels and that was almost too big. |
05-16-2018, 03:23 PM | #9 | |
Drives: 2013 SS Supercharged Convertible Join Date: May 2013
05-17-2018, 01:50 AM | #10 | |
Why do you think the Z/28 also has staggered wheels, but a square setup in the tires? Given that the car isn't really "for the masses".
05-17-2018, 03:28 AM | #11 |
Run 4 10” +23 offsets all around. You would have a difficult time making an 11” wheel fit and clear up front.
05-17-2018, 08:38 AM | #12 |
Agree - 20x10 all around with a +23mm offset is a great option.
The Z/28 and 1LE both use that strategy of having the wider rim with the same size tire on the back. I have dug a LOT into that and found very little information. From what I understand, the same size tire stretched onto a wider rim heightens the responsiveness of the tire. The wider rear tire was likely selected to bring a certain feel to the car. Others may be able to give a better idea on specifically how that works.
05-24-2018, 08:14 AM | #13 |
The 285-35 tire looks to be shorter than the stock 275-40. My 2011 has an unaltered suspension. Has anyone put this combination together and been unhappy with the look? I'm wondering if it opens up too much wheel well, or if you even notice the difference...
05-24-2018, 11:45 AM | #14 |
Look at a 1LE. It runs a 285-35-20 all around without being lowered from the factory.
