11-20-2013, 01:40 PM | #1 |
Drives: 2014 Yellow Camaro 2SS RS M6 Join Date: Oct 2013
Can I put a 315/35-20 on a 20" x 10" Wheel???
I have a 2013 1SS/RS Camaro M6. I have my new rims all picked out for it, but I was told by a certain retailer that I cannot run a 315/35-20 on a 20" x 10" on the rear wheels. They told me that minimum wheel width should be 10.5" for this tire size. Is there a major safety issue with this? Will I be replacing my 315 tires every year due to excessive wear because the wheel is too narrow? It would be for "Fun" driving, maybe 5000 to 7500 miles per year use, not for drag racing or street racing, but, if I want to kick it and do 100 to 120 mph every once in a while, would I have to worry about a blowout? Thanks in advance to all who respond.
11-20-2013, 01:51 PM | #2 |
Drives: 2010 2 SS Join Date: Oct 2013
11-20-2013, 02:01 PM | #3 | |
11-20-2013, 02:05 PM | #4 |
It's not optimal, but it can be done. You will just have more sidewall flex and a reduced contact patch. You should see the tiny wheels guys put wide rubber on for autocross. I've seen 285's on a 7" wheel! haha
Best regards, Tyler 888-308-6007 |
11-20-2013, 02:07 PM | #5 |
Drives: Widebody 2013 Mustang GT Join Date: Feb 2012
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
^^ Tyler basically covered it. It's do-able, but it's not optimal. Largest I really recommend on a 10" wide wheel is 305, and that's still pretty beefy.
11-20-2013, 02:11 PM | #6 |
So Cal Race Team
Drives: 2013 Camaro Join Date: Mar 2010
Kind of depends on the brand tire too, some are narrower in a 315 like Nitto, others like Michelin run wider...check the specs on the tire witdth's when selecting tire.
11-20-2013, 05:42 PM | #7 |
Drives: 2010 2SSRS headers/CAI/tune/corsa, Join Date: May 2010
Lot of us run 315 on a 10" wheel . I said a lot !!!!
Also this will help from getting curb rash on your New wheels
Stainless works headers/cats Roto fab CAI /
Corsa install and tune Livernois TSW Nuburgring 9 &10" x 20 on Invos (315 & 275 ) JL Audio XD400/4 amp Pfadt trailing arms & tie rods sway bars. pedders street 1 package. ,Hurst short throw shifter With bronze bushings . |
11-20-2013, 06:37 PM | #8 |
All day! The Invo's do run a little skinny though.
11-20-2013, 07:01 PM | #9 |
Do the invoes really measure small ? Has anybody actually measure them with the caliper
11-20-2013, 07:08 PM | #10 |
So Cal Race Team
Yes, the Nitto's are narrower...I have 295/35-20 Michelin's that are as wide as the Nitto 315's..there is a thread on this...
http://www.camaro5.com/forums/showth...nitto+michelin
11-20-2013, 07:54 PM | #11 |
That's what I thought...that a lot of C5 owners were running 315's on 10" wheels. If there is not a safety issue with this, and there doesn't seem to be, then I'm putting 315's on my new 10's when they get here.
11-20-2013, 08:37 PM | #12 |
Drives: 2013 SS Join Date: Sep 2012
Here ya go
11-21-2013, 06:49 AM | #13 |
OK...Here is my plan of action:
Fronts: 20x8.5 wheels with 32mm offset and 275/40-20 tires Rears: 20x10 wheels with 34mm offset and 315/35-20 tires With this combination, can anybody tell me if I would have any rubbing or clearance issues? (car is not lowered and the tires would be Michelin Pilots on the rears and Pirelli P-Zeros on the fronts). Last edited by BRUKSHOT; 11-21-2013 at 07:14 AM. |
11-21-2013, 08:59 AM | #14 | |
now the question is, is it all Nittos that run narrow or is it just the Invos? |
