05-12-2016, 05:17 AM | #1 |
Camaro #4
Drives: 2017-Hyper Blue Metallic-2LTmanual Join Date: Dec 2015
I wonder what would happen ... methanol on a N/A engine ...
I was looking at the *Snow Performance website at their methanol injection systems, and they have one for N/A - Boosted gasoline engines. I've heard about using water injection to clean combustion chambers long ago and after reading the description at Snow Performance, I was wondering - If the system was set up to inject the methanol only at higher RPMs to avoid 'drowning' the engine, what would happen when the methanol/water mix hits the backs of the hot intake valves?
Would the alcohol dissolve the carbon crud? Would the transformation of water/alcohol to steam-vapor blast the crud off and let chunks enter the combustion chamber? Would it do nothing at all? I took this off the Snow Performance website and posted it here to see what everyone thought. Benefits:
Don M
Supercharged LGX + 6 speed manual = FUN!! |
05-12-2016, 05:35 AM | #2 |
Drives: 2015 1LS Red V6 Join Date: Aug 2015
Same thing for E85...and cheaper.
Sponsors:
Overkill Motorsport BCS Auto JacFab Machining APDEG Dream Gear Mobile Audio Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet 5th Gen V6 Performance Facebook Group |
05-12-2016, 07:23 AM | #3 |
Drives: 2015 Black 2LT RS M6 Join Date: Aug 2015
Interesting
Overkill tune/E85/80mm•CAI cold air intake w/my custom maf tube•Apex air scoop•JacFab ported intake/Extendolater•Vitesse•EE EX2 catch can•Innovate wideband•ARH HFC's•NPP exhaust•11386 xpipe•Brembos/cross drilled/slotted rotors•SS M/C•Pfadt 1.25 springs•1LE struts/sways/strut tower brace•BMR diff bush, trail arms/bush, adj toe links•My custom Tunnel brace•Hurst short throw shifter•JDP stage 1 clutch res•1LE steering wheel, shift boot•ZL1 rear diffuser/splash guards•GM splitter•Z/28 grille/flowtie/spoiler/wheels•GM performance pedals•"Chevrolet" door sills•10" Kicker sub•BigWorm overlays
05-12-2016, 07:30 AM | #4 |
Too much is never enough!
Better off doing nitrous.
Methanol works best if your needing to control detonation limits. On a non forced induction car, this is rarely the case, and nitrous will be a much more effective power adder (and quite safe if you set it up right) for the time and expense involved. However this little write up shows some interesting info. Still IMO not worth it. http://www.corvetteforum.com/forums/...lications.html
05-12-2016, 03:35 PM | #5 |
Banned
Drives: 2015 Camaro 1LS M6 Join Date: Jan 2016
With the way I can feel knock retard affecting the performance of my LFX with the crap gas we have available here, it might be worth checking into.
