01-31-2021, 01:44 PM | #1 |
Drives: 2011 Synergy Green 2SS/RS Camaro Join Date: Jan 2011
Rear camera for my 2011 SS
Sorry if this has been covered but could not find anything for help.. What if anyway can I put a rear back up camera in my 2011 SS. I would like a stock look in the dash if at all possible. Don't want to break the bank but any ideas out there? Thanks for all the help
01-31-2021, 02:16 PM | #2 |
Drives: 2011 camaro 2ss convertible Join Date: Aug 2020
in my case i changed out the head unit and installed the camera where the license plate light it...
02-02-2021, 03:26 PM | #3 |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
I put the back up camera kit in my 2010 from Gen5DIY, cost $471. It is plug and play. Comes with a new rear view mirror. Easy to install.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
02-12-2021, 12:57 PM | #4 |
SS Camaro can you send me a link where you bought it please.
02-12-2021, 01:53 PM | #5 |
02-14-2021, 09:41 AM | #6 |
I did mine for less than $100 and kept it stock looking. I wired the power to the reverse lights. System only comes on when transmission is in R.
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts, 1.4" BMR lowering springs ZL1 factory rims misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete |
02-14-2021, 03:57 PM | #7 |
The Gen5DIY camera picture is in the inside mirror.
02-16-2021, 08:43 AM | #8 |
Drives: 2011 Camaro SS Join Date: Nov 2017
I went this route...
I choose this camera because it just has a clean, integrated look and doesn't require any drilling. I think it's the same camera that comes on other GM vehicles.
My Little Mid-Life Crisis Cure!
First - 1997 Camaro 3800 Y87, M5, Green - Gone | Second - 1997 LT1 Z28, M6, Silver - Sold | Third - 1999 LS1 Z28, M6, Pewter, Almost Stock! - Sold Current - 2011 Camaro SS, M6, black, 1LE suspension parts - Current |
02-16-2021, 09:28 AM | #9 |
Drives: 2010 2SS/RS Join Date: Dec 2009
There’s a Gen5DIY kit in the audio thread fall for 10-11 Camaro’s.
Orange Krush II
