02-25-2018, 02:06 AM | #1 |
Drives: 2012 SS L99 Converible Join Date: Mar 2016
Stock ported or full aftermarket throttle body?
Kicking around the idea to do something with the throttle body since I have a new full exhaust, headers, highflow cats, and CIA. If going aftermarket should I look for a larger throttle body? What’s everyone’s experience????
2012 L99 Convertible SS
Tooley Racing Stage 2 DOD delete, 3,200 stall converter, Shorty headers and custom stainless exhaust, CAI, and tune as mods |
02-25-2018, 02:27 AM | #2 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
I'd get a stock ported one if you're able, specifically the stage 2 Bo White. Going large than stock size won't benefit you enough to make it worth the cost until you do an intake manifold and possibly even heads I would assume haha.
*SOLD*504HP/433TQ | Night Fury cammed • Cold Air Inductions intake • Bo White ported TB • Speed Engineering 1 7/8 longtubes • NPP catback • QTP low profile cutouts • Powerbond 25% UDP • 3.73 gears • JRE scoop • ZL1 grille • R1 Concepts drilled/slotted rotors • built/tuned by Weapon X Motorsports
02-25-2018, 03:05 AM | #3 |
Drives: 2014 Camaro SS L99 Join Date: Nov 2017
+1
MODS: GPI MAX Package ported and milled heads+(229/250,111 LSA),Johnson 2110 Lifters,BTR .660 Springs,CHE Trunnions,C5R chain,DSX Flex Fuel kit,LSA Injectors,ZL1 Fuel Pump,MAMO Ported MSD Intake manifold,BOWhite ported Throttle body,25% UDP,CAI Intake,Intake Scoop,Kooks 1 7/8 headers,Borla attak catback,Elite catch can,BMR Motor mounts,CircleD 5C 4000-4200 Torque converter,ADM trans cooler,Jannetty Trans dipstick,DSS Aluminum Driveshaft,3.91 Gears,Eaton TrueTrac,JRE Billet caps,BMR Trailing arms,BMR Toe rods,BMR rear sway bar,Pegasus Solid sub frame bushings,DSS 1,000HP Axles
02-25-2018, 06:44 AM | #4 |
Go with Bo! His PTB's are the best hands down.
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
02-25-2018, 07:21 AM | #5 |
Drives: '14 BRM 1LE 2SS/RS Join Date: Nov 2017
How do you get one of these? Just PM Bo directly?
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC |
02-25-2018, 07:40 AM | #6 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
Yes, send him a pm... he'll give you shipping info. Quick turn around...had mine done b4 Christmas.
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
02-25-2018, 08:51 AM | #7 |
Started#gottalovethatblue
Go with a ported tb from Bo White as others have said. One of the best mods for a L99 out there! Going with a larger throttle body will only benefit you if you have a larger intake for it to breathe in on a large power vehicle. PM Bo on here and he will get you squared away! If you do go with a manufactured tb go Vmax, but stay away from BBK. BBK throttle bodies have been known to stick. They make tons of other really great products but their ported throttle bodies aren’t known to be one of them.
02-25-2018, 08:55 AM | #8 |
Drives: 2011 ss Join Date: Sep 2015
I also went Bo
02-25-2018, 08:57 AM | #9 |
old school chevy rodder
Or you can get a vmax ....
02-25-2018, 11:23 AM | #10 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Slightly used TB's are plentiful. Pick on up for @$100, and do the job yourself. Not saying at all that work by Bo or other professionals isn't top notch, but I researched the hell out of it, and then used my dremel to do the job myself. Was very satisfying, and I knew I had the OEM I removed if I messed anything up. I think the job came out great, noticed a decent improvement, specifically on throttle tip in, and have had no issues since installing it over a year ago. I also just completed an LSA swap, and reused the ported TB, again, no issues. It's not rocket science, but does take patience and being careful to not try and go too far with the smoothing.
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
02-25-2018, 12:48 PM | #11 |
Yeah either way get it ported. You don't need an aftermarket one.
Vmax offers cnc You can do it yourself Or you can send it off
02-26-2018, 02:32 AM | #12 |
Ok thanks guys. My son has expressed interest as he needs a project for school. He is in a machinist apprenticeship program and runs cnc stuff as well as manual milling equipment.
02-26-2018, 02:40 AM | #13 |
Awesome. I went through one in the mid 90s.
02-26-2018, 03:07 AM | #14 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
i have a vmax. wanted to go with Bo White but i didnt get in on the deal in time when i was shopping for one just before XMAS 2016. Heard nothing but great feedback on his PTBs
Bone Stock |
