09-06-2014, 11:51 AM | #1 |
Drives: 2013 ZL1 Convertible Join Date: Oct 2013
Ported Blower/Snout HP Gains???
Anyone out there do before and after dyno pulls with only changing to a ported blower, snout or both? I'm thinking about going this route and would like to know if it's truly worth the expense.
2013 ZL1 Auto Convertible - BRM
Best: 10.829@127.15 FI Interchiller, Roto-Fab CAI, Big Gulp & Res, 9.1/2.5 Pulleys, PB&S, DeatschWerks 1500cc, Fore triple pump, Pfadt LT's, RD HX, MT DR's New times to come with E85 2016 2SS Auto - Hyper Blue Metallic Roto-Fab CAI |
09-06-2014, 12:10 PM | #2 |
Drives: none Join Date: Aug 2011
I've heard and read anywhere from 5 to 30 HP depending on who does the porting.
09-06-2014, 12:16 PM | #3 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
I had my 1.9 snout ported and I had some porting done on the 2.3 and its snout. I always did the porting in conjunction with another list of modifications. I think the actual gains will depend on how hard you are pushing the air through the car. If you are running stock pulley ratios you may only see a 5 hp difference but the more pulley you run on the car the more the airflow in the supercharger and snout will effect the bottom line. You can really take a lot of metal out of that 1.9. ADM had some examples that he had done like 30 hours of porting work on. I don't know who you are considering for the work but if you talk to Andy at ADM Performance he probably knows right off the top of his head. It is not the cheapest way to get power but after everything else has been changed eventually you may want to go there.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
Thread Tools | |
