01-24-2020, 09:33 PM | #1 |
Drives: Camaro SS 2013 Join Date: Jan 2018
Can i use 285s as the front tires on my 13 ss??
01-24-2020, 09:37 PM | #2 |
Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
Yes
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
01-25-2020, 05:38 AM | #3 |
Drives: 2010 Cyber Gray LS3 SS/RS Join Date: Jul 2017
Depends on what wheels, won’t fit on stock wheels unless they’re 1le or zl1. But yes 285 are the stock tire size on 1le’s and I’m running them on my SS.
2010 Cyber Gray LS3-BTR stage 4-480/428 RXT and 3.91’s
01-25-2020, 05:46 AM | #4 |
SS oem wheels are 20x9 front and 20x10 rear correct? 285s will fit both of those. If they are 20x8 and 20x9s 275s will fit all 4 corners.
01-26-2020, 09:53 AM | #5 |
BowtieBelle's SS
Drives: 2010 Camaro SS Join Date: Jan 2012
Non 1LE are 20x8 and 20x9.
285 would fit the wheel but pooch out. I wonder if it would clear the spring.
01-26-2020, 10:36 AM | #6 |
Drives: 2014 1le 1SS CRMT Join Date: Apr 2014
Absolutely you can
I run 295/35/20’s |
01-26-2020, 10:41 AM | #7 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Not sure, I run 28x5x17 on the front.
01-27-2020, 12:04 AM | #8 |
Drives: Velvet Blue Metallic 2015 1SS 1LE Join Date: Apr 2018
The answer depends on the wheels. Running a 285 on an 8 inch rim doesn't sit well with me. It'll fit on a 9 inch rim, but it's not exactly ideal. If your talking about a 10 inch rim, do it! You could even pull off a 295 if you want. But it'll all fit under the fender without modification. No worries.
