Old 07-01-2016, 11:28 AM   #1
HAMBO
HAMBO's Avatar
Drives: Supercharged 2013 AGM 2SS/RS
Best way to clean surface rust of brake rotors?
Hi everyone,
Have some, what looks like, surface rust on the brake rotors. Not on the smooth surface, but on the portion in the center. I can scratch it with my nail and it comes off a bit. Wondering what the best way to clean it off is?
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports.
1967 Bolero Red 396 SS/RS Convertible
HAMBO is offline   Reply With Quote
Old 07-01-2016, 01:48 PM   #2
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
A wire brush will knock it off, but it will return as soon as it gets wet again. It's bare metal and surface rusting is normal.
Painting with caliper or high temp paint is best option. I need to do mine, but have no level place where I live to jack it up.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
Old 07-02-2016, 04:46 AM   #3
BRZN
BRZN's Avatar
Drives: 2012 1LT
Its bare metal, and being such will always show surface rust, paint 'em:
http://www.por15.com/POR-15-High-Temp_p_104.html
While your at it do the Calipers too:
http://www.por15.com/POR-15-Caliper-...8-OZ_p_41.html
With Michelle's car being dark, not only did we do away with surface rust on the rotors, but the black painted rotor hats and calipers behind the black wheels makes it all fade away from sight!
Such a clean look
BRZN is offline   Reply With Quote
Old 07-02-2016, 08:45 AM   #4
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
I agree paint is the only way to go.
Old 07-02-2016, 09:32 AM   #5
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Scotch brite pad and duplicolor caliper paint. I used brush on, not spray, it has nice self leveling properties.
Old 07-02-2016, 11:34 AM   #6
14ssrs6man
14ssrs6man's Avatar
Drives: Summit White 2014 2SS/RS 6spd
Nice!
Your car must be very fast! You were haulin' ass when I passed you!
14ssrs6man is offline   Reply With Quote
Old 07-03-2016, 05:34 AM   #7
BRZN
BRZN's Avatar
Drives: 2012 1LT
I used the Duplicolor Caliper Paint on the rotor hats, fins and veins on my 2006 GTO. It began chipping off before the next oil change. Everything had been disassembled cleaned and prepped according to their instructions.
No bueno.
You get what you pay for. The POR-15 product sets up hammer hard like powder coating.
Old 07-03-2016, 05:45 AM   #8
14ssrs6man
14ssrs6man's Avatar
No bueno.
Chassis Saver by magnet paints looks good too... I have seen great reviews from the truck world. Am going to try on my Aspen DD on the rockers and door bottoms to fix some rust, then going to go over with their Monstaliner to protect. I will let you know how it works.
Old 07-04-2016, 08:42 PM   #9
PAUL SS
PAUL SS's Avatar
No bueno.
Mine were painted four years ago. I cleaned everything with brake cleaner, no chips no peeling or flaking.
Old 07-05-2016, 12:01 PM   #10
BRZN
BRZN's Avatar
Drives: 2012 1LT
Perhaps you got lucky, and I didn't. I disassembled everything; removed caliper to pull the caliper bracket and rotors off. I cleaned with several different wire brushes and sand paper. I too, then, cleaned everything with Brake Clean to remove any remaining dust, dirt, and oils. Below are a few pictures I found.
Freshly painted with the Duplicolor Caliper Paint:
After about 4,000 miles:
Freshly painted with POR-15 High Temp Black Velvet:
Old 07-05-2016, 12:21 PM   #11
davesnever
davesnever's Avatar
Drives: 2010 Camaro 2SS
I notice you are in PA, are any of those 4000 miles driven in the winter time?
davesnever is offline   Reply With Quote
Old 07-05-2016, 12:52 PM   #12
BRZN
BRZN's Avatar
Drives: 2012 1LT
LOL, no. Not driven in any inclement weather. Garaged most all the time.
Old 07-11-2016, 06:05 AM   #13
rdanzel
Drives: 2010
Any high temp paint should work. Just clean and prep the surface well.
rdanzel is offline   Reply With Quote
