05-20-2020, 05:54 PM | #1 |
Drives: Black 2010 SS Join Date: Oct 2013
Cam Help and what to buy
Looking to cam my 2010 SS just havent made up on my mind on what cam and what i need to exactly buy. Ive been looking to do either night fury or TSP F-35. If anyone could give me some advice much appreciated.
05-20-2020, 06:17 PM | #2 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Auto or stick car?
05-20-2020, 06:25 PM | #3 |
Stick
05-20-2020, 07:12 PM | #4 |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
These are heavy cars , you might want to consider smaller cam to keep the curve fat. Or not
Just saying peak hp is not everything on a almost 4000lbs car
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
05-20-2020, 07:17 PM | #5 |
Here's a list of things most people do when doing a cam. Melling oil pump, ls2 timing chain dampener, timing chain (wouldnt do a double roller as they have clearance issues), 3 bolt cam and gear, hardened pushrods, lifters, .660 lift valve springs, valve seals, rocker arm trunion kit. I recommend CHE or btr V2 kit. Most places have cam kits that include a lot of that stuff. If you don't want to pull the heads to do the lifters you don't have to. If you don't want to pull the oil pump you don't have to, but then you can't change the timing chain or tensioner. Cam grind i won't get into, I'd call btr and tell them what you want they will pick one off the shelf or you can custom grind, go for the premium cam core it's worth the extra few bucks.
05-20-2020, 07:41 PM | #6 | |
Drives: 13' 1LE Join Date: Apr 2012
F-35, but I would consider their stage 3. The older version did good for me and was on the safer side for PTV. More streetable too, easier to tune. If your car is a DD, consider going with a custom cam. If you plan on doing gears and all the boltons its a good plan. A big cam is cool.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
05-21-2020, 07:52 AM | #7 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
05-27-2020, 10:13 AM | #8 | |
Drives: 2014 1LE Join Date: Apr 2019
TSP F-35 cam
check out this dyno graph car had bad spark plugs and clogged air filter mods: Airaid intake 178 TSP LT 25% underdrive |
05-27-2020, 11:24 AM | #9 | |
Drives: 15 Camaro SS Join Date: Oct 2018
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
05-27-2020, 11:55 AM | #10 | |
Drives: Camaro 1LE Join Date: Jan 2020
I would change the lifters depending on how many miles you have on the car. Last thing you want is to do is tear that engine down, if the lifter malfunctions. Then you run the risk of getting the cam eaten up. Cam wise- is this your first cammed car? I was initially going to put in a night fury cam in my SS but I traded that in for a C7Z. . A lot of people ran it and it netted good results. Why change the wheel if it’s not broken. On the other side of things, you might not like the bigger cam since it’ll require more throttle to get up and going. Typically not good for daily drivers, but from my experience it’s all in the tune and what you’re willing to tolerate. |
05-27-2020, 02:11 PM | #11 |
Drives: 2015 1LE Join Date: Oct 2015
what do you want from the car?
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
05-27-2020, 07:58 PM | #12 |
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche Join Date: Jan 2019
I have a new in box Tick Performance Street Heat Stage 2 Camshaft by Cam Motion.
229/244 | .618”/.610” | LSA112+4 for sale $300 shipped if you interested! |
05-27-2020, 08:29 PM | #13 |
that is always a good choice!
05-27-2020, 09:26 PM | #14 |
Drives: 13 1LE 1SS/05 ZX10/02 Silverado/14 Join Date: Nov 2014
You should check out GPI. I’m running their SS4 in a stick car and it’s very fun
02 Stepside Silverado
05 ZX-10 13 1LE 14 Nightrod Special |
Thread Tools | |
