Old 08-18-2019, 12:03 PM   #1
2015ghost
2015ghost's Avatar
Drives: 2015 2SS Stock
Really bad day
Just finished wrapping my new front lip spoiler and installed it this morning. On my first drive at 60mph it ripped off and was destroyed. I installed it with all the little clips and such as recommended by the manufacturer, so I don’t know why happened. $460 down the drain. Sunday ruined.
2015 2SS auto. AGP twin turbo, LS9 cam, BTR 660 springs, LS9 Gaskets, ARP studs, 400lph UPP fuel system, MBRP XP 3” cat back, 305/30 Micky Thompson Sport comp tires. 12” Fockford fosgate P1, Rockford Fosgate 600w amp.
2015ghost is offline   Reply With Quote
Old 08-18-2019, 12:25 PM   #2
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
Sorry man, that really sucks.
CAI Cold Air Intake; Comp Cams LSR Series; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; AEM Wideband; N2MB WOT Box;
Tuned by Throttle Works 467whp 419 wtq
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 08-18-2019, 12:58 PM   #3
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
Didnt it come with screws too? What brand was it?
Sent from my SM-N960U using Tapatalk
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 08-18-2019, 01:00 PM   #4
spyderbuddy
spyderbuddy's Avatar
awh, man that sucks, you did wait the 24 Hrs before driving it Right?
Looks almost like the LLT 2010 Air damn
It had little metal clips that went in on the sides
I know because Chevy had to replace mine
They had orginally install the SS version on the V6 and they are a little different
TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
Old 08-18-2019, 02:27 PM   #5
2015ghost
2015ghost's Avatar
It was the ACS composite purchased through phasetek. I don’t blame anyone it’s weird and heartbreaking it happens but I can’t figure out why. I used all the factory plastic acres and the 2 main bolts and drilled for the extra push pins.
Old 08-18-2019, 02:50 PM   #6
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
I wouldn't throw it in the trash just yet. Contact ACS and Phastek and see what they say.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 08-18-2019, 06:34 PM   #7
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
I agree with fred. If you truly follow the install instructions and it broke off it may be faulty....
Or is there more to the story???
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
