09-26-2016, 01:59 PM | #1 |
JANNETTY RACING ZL-1 800 PACKAGE COMPLETE 707 RWHP 648 RWTQ
Just off the dyno with one of my long time customers over 30 years.
2012 ZL-1 previously had our JRE ZL-1 750 package and he wanted to step it up. We put 100 octane in the tank, added 28% crank pulley and a 90 mm TB. Results 707 RWHP 648 RWTQ on Only 12.5 to 13 psi boost. Features; Rotofab CAI Vmax ported 90 mm TB JRE rough Idle road race special. ATI superdamper LPE-28% pulley Metco 50 mm Idler Dynatech LT headers ceramic coated. Dynatech Supercats. Stock exhaust Moroso catch can JRE Crankcase breather. JMS fuel pump voltage booster ID-850 injectors. SCT X4 tuner JRE custom tuning.
www.jannettyracing.com
09-26-2016, 02:35 PM | #2 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
LoL, can I send back the 22.5 for the 28?
Cant wait to get everything installed and rolling. |
09-26-2016, 03:20 PM | #3 |
If you're willing to run race fuel, Yes sir.
09-26-2016, 04:02 PM | #4 |
Team 913
I run 100 at the track and 91 around town...
09-26-2016, 04:04 PM | #5 |
KaBoom1701
Very nice Ted. Congrats.
I can just add the cam and a tune and be right there with some 100 octane. lol
Mods:
09-26-2016, 05:29 PM | #6 |
Drives: 2015 ZL1 Join Date: May 2015
would 2 cans of torco also work for the 100 octane?? instead of race gas
also is that the way your cams are set up to make most of the torque at low to mid RPMs.. would a 22.5% pulley be close to the 28% on 100 octane and make less heat? Last edited by fluxzl1; 09-26-2016 at 05:51 PM. |
09-27-2016, 07:00 AM | #7 |
Drives: ZL1 Convertible Auto Join Date: Apr 2015
This is almost exactly what I have from JRE. I am not using cats and have the stock throttle body.
Anything learned from the tune that could change my tune?
LS3 intake and throttle body, Huron Speed Products twin turbo with 6265 oil less turbos, and 3" header back, JRE smooth cam, ID1300, Fore dual 450lph pumps with MSD voltage booster, A6, 305/45/17 MT Street R
10-02-2016, 06:33 PM | #8 |
PURBRED
Drives: 2014 Camaro ZL1, 2007 Gmc Duramax Join Date: Dec 2013
What are the specs on the rough idle cam?
10-03-2016, 07:47 AM | #9 | |||
You will need 2 tunes to take advantage of the octane.
We also really never know what the pump fuel octane is because of age and if 87 was mixed in at the station, Yes It happens. So it is always best to purchase 100 octane in cans or purchase it at a gas station that carries it. The speed we turn the blower determines How many lbs. of air per minute the blower moves, for example 1 lb. of air per minute makes 10 HP. We are sqeezing every bit of power out of every lb. of air flow so we have to spin the blower faster to make more power. 100 Octane is usually worth about 25-30 RWHP over premium pump fuel with proper tuning. Quote:
I provide a cam card with ever cam I sell, but I respectfully do not post them, I will tell you our cams make more power on less boost than any we have tested. Thank you gentlemen. Ted.
12-21-2016, 12:29 PM | #10 |
Merry Christmas and Happy New Year.
Open for discussion.
12-21-2016, 02:08 PM | #11 |
Drives: 2021 Camaro ZL1 Join Date: Sep 2016
I've spoken you with before on the specs of my car. Bought the car as a trade in from my dealer I work for on Long Island. 2014 zl1 ...
You mentioned I have the 750+ hp package. Curious with seeing these numbers what the next logical step would be. I'm all for gathering parts now and found the work in the warmer months and prefer work to all be done by the same shop to make sure everyone knows what's going n with the car. My head tells me that some port work is is order. Snout, blower, TB and heads. All of which leaves me with questions as to what extent of port work and if it's worth it. Advantages of the NW102 throttle body over the 90mm? Esp if I'm talking about blower porting? Maybe a different direction all together? Sent from my iPad using Tapatalk |
12-21-2016, 02:45 PM | #12 | |
An E-85 conversion would be the first move if you would allow me to make the decisions. We can either talk about it here or you can call me directly whichever you think will be more fun
12-21-2016, 09:03 PM | #13 | |
Drives: 2015 ZL1 Bright Yellow Join Date: Apr 2014
12-22-2016, 07:22 AM | #14 | |
I have seen variances of 70 RWHP between 93 and E-80. Of course the lower starting HP the less the gain because your starting further from the octane wall. My Pleasure sharing my experience. Ted.
